Problem in output relay
Good afternoon,
I flashed several times the KC868-A16S board with ESPHome firmware but the relay n. 8 remains always in on state (also the status led on the board) and it is impossible to control it.
This is the last firmware (still with the problem) :
  friendly_name: Centralina citofono
    type: arduino
  encryption:
    key: "E3acLht11PoN5oLlgBJPgIO/+elvX80lTzGbQPfVnH8="
ota:
  - platform: esphome
    password: "0b4d665617eac63f109a0dd7b51a409e"
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
    address: 0x24
    address: 0x25
    address: 0x22
    address: 0x23
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode:
        output: true
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
  - platform: restart
    name: EspHome Node Restart
      pcf8574: pcf8574_hub_in_1
      number: 4
      number: 5
      number: 6
      number: 7
      pcf8574: pcf8574_hub_in_2
      number: 4
      number: 5
      number: 6
      number: 7
Can You help me ?
Problem in output relay - by Bergoglio - 12-27-2024, 11:17 AM
RE: Problem in output relay - by admin - 12-28-2024, 01:35 AM
RE: Problem in output relay - by Bergoglio - 12-28-2024, 10:57 AM
RE: Problem in output relay - by admin - 12-29-2024, 12:11 AM
