using 5v-12v as input sensor
#15
I'm wondering if you could abuse an NPN sensor, which switches the GND side, to do this?  Looking at the first link you provided:
that switches the load to GND, so if you take the black wire and connect it to the KC868 input, with the KC868 and sensor sharing the same +12V and GND, that might work.  You'd probably want to get one or two of the sensors first and check that the black wire is open-circuit to GND when not triggered and closed-circuit to GND when triggered before you connect them to the KC868.
using 5v-12v as input sensor - by amararsa24s - 09-08-2024, 11:05 AM
RE: using 5v-12v as input sensor - by admin - 09-08-2024, 11:26 AM
RE: using 5v-12v as input sensor - by amararsa24s - 09-09-2024, 07:08 PM
RE: using 5v-12v as input sensor - by amararsa24s - 09-09-2024, 06:10 PM
RE: using 5v-12v as input sensor - by admin - 09-09-2024, 11:03 PM
RE: using 5v-12v as input sensor - by amararsa24s - 09-10-2024, 07:32 AM
RE: using 5v-12v as input sensor - by amararsa24s - 09-11-2024, 05:08 PM
RE: using 5v-12v as input sensor - by admin - 09-11-2024, 11:42 PM
RE: using 5v-12v as input sensor - by amararsa24s - 09-12-2024, 06:31 AM
RE: using 5v-12v as input sensor - by amararsa24s - 09-14-2024, 11:11 PM
RE: using 5v-12v as input sensor - by tanoshimi - 02-01-2025, 03:01 PM
RE: using 5v-12v as input sensor - by twostar - 02-02-2025, 12:13 AM
RE: using 5v-12v as input sensor - by admin - 02-02-2025, 12:39 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-02-2025, 09:28 AM
RE: using 5v-12v as input sensor - by twostar - 02-02-2025, 10:04 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-02-2025, 10:26 AM
RE: using 5v-12v as input sensor - by twostar - 02-02-2025, 10:35 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-02-2025, 10:44 AM
RE: using 5v-12v as input sensor - by twostar - 02-02-2025, 11:21 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-02-2025, 07:47 PM
RE: using 5v-12v as input sensor - by twostar - 02-03-2025, 03:44 AM
RE: using 5v-12v as input sensor - by tanoshimi - 02-03-2025, 07:56 AM
RE: using 5v-12v as input sensor - by admin - 02-03-2025, 05:32 AM
RE: using 5v-12v as input sensor - by twostar - 02-03-2025, 05:35 AM
