KC868-A32 configure for ESPhome
#18
Yesterday I received my first Kincony KC868-A32 board and tried to install ESPHome.
I initially used the configuration described in the first post, but I had to make some changes as it was no longer compatible with the new version of ESPHome.
The first operation I performed after saving the configuration was validation, where the following warning was displayed:
INFO ESPHome 2025.8.2
INFO Reading configuration /config/esphome/kc868-a32.yaml...
WARNING GPIO15 is a strapping PIN and should only be used for I/O with care.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
Is it possible to change the PIN to avoid the warning?
Is this a warning that can be ignored?
The changes made in the original example are:
1. The platform and Framework
  platform: ESP32
To:
  friendly_name: KC868-A32
    type: esp-idf
    version: recommended
2. Added the Wifi (commented in my case because I use Ethernet) and Ethernet configuration and enabled the Web Server to test the configuration:
# Wifi section disabled to use Enthernet
#wifi:
#  ssid: !secret wifi_ssid
#  password: !secret wifi_password
## Enable fallback hotspot (captive portal) in case wifi connection fails
#  ap:
#    ssid: "Kc868-A32 Fallback Hotspot"
#    password: "GmVxfzYtDqBl"
#captive_portal:
# Ethernet section used instead of Wi-Fi
# Ethernet Example configuration entry (It's possible to use only WIFI or only Ethernet, not both)
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk:
    pin: GPIO17
    mode: CLK_OUT
  phy_addr: 0
  manual_ip:  # Recommended for router compatibility
    static_ip: 192.168.1.183
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    dns1: 8.8.8.8            # DNS primary
    dns2: 8.8.4.4            # DNS secondary
# Alternative debug and OTA web server
web_server:
  port: 80
  version: 2
  include_internal: true
3. Changed the attenuation value for the adc from 11db to 12db
  - platform: adc
    pin: 39
    update_interval: 10s
    attenuation: 11db
  - platform: adc
    pin: 34
    attenuation: 11db
  - platform: adc
    pin: 36
    attenuation: 11db
  - platform: adc
    pin: 35
    attenuation: 11db
To:
  - platform: adc
    pin: 39
    attenuation: 12db
  - platform: adc
    pin: 34
    attenuation: 12db
  - platform: adc
    pin: 36
    attenuation: 12db
  - platform: adc
    pin: 35
    attenuation: 12db
It might make sense to update the first post with the latest changes to the latest version of ESPHome!
KC868-A32 configure for ESPhome - by admin - 03-23-2022, 12:36 PM
RE: KC868-A32 configure for ESPhome - by nwells - 03-03-2023, 12:51 AM
RE: KC868-A32 configure for ESPhome - by admin - 03-03-2023, 02:36 AM
RE: KC868-A32 configure for ESPhome - by nwells - 03-03-2023, 04:30 AM
RE: KC868-A32 configure for ESPhome - by nwells - 03-03-2023, 06:10 AM
RE: KC868-A32 configure for ESPhome - by admin - 03-03-2023, 09:02 AM
RE: KC868-A32 configure for ESPhome - by nwells - 03-03-2023, 09:12 AM
RE: KC868-A32 configure for ESPhome - by admin - 03-03-2023, 09:53 AM
RE: KC868-A32 configure for ESPhome - by nwells - 03-03-2023, 10:00 AM
RE: KC868-A32 configure for ESPhome - by admin - 03-03-2023, 10:34 AM
RE: KC868-A32 configure for ESPhome - by nwells - 03-04-2023, 12:06 AM
RE: KC868-A32 configure for ESPhome - by admin - 03-04-2023, 12:48 AM
RE: KC868-A32 configure for ESPhome - by nwells - 03-04-2023, 01:18 AM
RE: KC868-A32 configure for ESPhome - by admin - 03-04-2023, 01:32 AM
RE: KC868-A32 configure for ESPhome - by admin - 12-24-2023, 11:32 AM
RE: KC868-A32 configure for ESPhome - by REVELAS - 12-27-2023, 07:22 PM
RE: KC868-A32 configure for ESPhome - by gigios - 09-04-2025, 08:30 AM
RE: KC868-A32 configure for ESPhome - by admin - 09-04-2025, 12:23 PM
RE: KC868-A32 configure for ESPhome - by gigios - 09-04-2025, 12:52 PM
RE: KC868-A32 configure for ESPhome - by gigios - 09-04-2025, 12:57 PM
RE: KC868-A32 configure for ESPhome - by admin - 09-04-2025, 11:10 PM
RE: KC868-A32 configure for ESPhome - by tasman - 09-09-2025, 04:16 PM
RE: KC868-A32 configure for ESPhome - by admin - 09-10-2025, 12:48 AM
RE: KC868-A32 configure for ESPhome - by tasman - 09-10-2025, 06:24 AM
RE: KC868-A32 configure for ESPhome - by admin - 09-10-2025, 06:37 AM
RE: KC868-A32 configure for ESPhome - by tasman - 09-10-2025, 07:08 AM
RE: KC868-A32 configure for ESPhome - by tasman - 09-10-2025, 11:49 AM
RE: KC868-A32 configure for ESPhome - by admin - 09-10-2025, 11:47 PM
