08-05-2022, 05:40 PM
Thank you , here is the download log after install to check( attached)
Only input from 1-9 and unavilable not to 16 as well
And light from 1-16 and not seen on the card although i added several times.
See attached.
What i should do next mandatory before start setting up H32B?
I had apointment with electrician tomorrow morning to install the DB of outdoor that has the H32B and the teminal switch board and still until now working on MQTT through kbox and activate both 2 remote controls before starting to install the server and A16
Let me ask 3 important questions:-
1- what is mandatory to setup as a hardware and software as well as installation prior to setup H32B on the home asistance? And is it okay after connect to the load to change setting from Mqtt static ethernet snd wifi dhcp to mqtt dhcp ethernet through home asisstant and dtop the wifi?
2- how the system work and dependently on power supplies, i mean the server, A16, router, controllers all connected to normal suppy foes all of those connected to ups in case power failed to keep the system controllable?
3- i made most of my stetup for installation on my laptop, i want afterwords to reinstall the windows and re-image my apps and application what i need to re- setup again on the laptop from previous steps.
Please give me the main headlines and steps in correct sequence for what is mandatiry to do first before start configure the controllers and i can with time improve the other steps to check the system before start connected to load and be in service.
Thank you
Thank you again for help and support
See attached.
Thank you
