[Arduino source code for KC868-M16]-04 -Read / Write SD card arduino source code
#include "FS.h"
#include "SD.h"
#include "SD_MMC.h"
#define BOARD_HAS_1BIT_SDMMC
void WriteFile(fs::FS &fs, const char *path, uint8_t *buf, int len)
  //unsigned long start_time = millis();
  Serial.printf("write [%s]...\n", path);
  File file = fs.open(path, FILE_WRITE);
  if (!file) {
    Serial.println("Failed to open file for writing");
    return;
  if (!file.write(buf, len)) {
      Serial.println("Write failed");
      return;
  file.flush();
  file.close();
  Serial.printf("Write [%s] Complete", path);
void ReadFile(fs::FS &fs, const char *path, uint8_t *buf, int len)
  Serial.printf("read [%s]...\n", path);
  File file = fs.open(path);
  if (!file) {
    Serial.println("Failed to open file for reading");
    return;
  if (!file.read(buf, len)) {
      Serial.println("Read failed");
      return;
  file.close();
  Serial.printf("Read [%s] Complete: %s", path, buf);
void testIO(fs::FS &fs)
  char buf[] = "hello world";
  WriteFile(fs, "/test.txt", (uint8_t *)buf, strlen(buf));
  ReadFile(fs, "/test.txt", (uint8_t *)buf, strlen(buf));
  pinMode(2,INPUT_PULLUP);
  // put your setup code here, to run once:
  Serial.println("Please insert SD card");
  delay(1000);
  /* SD_MMC 1-bit Mode */
  if (!SD_MMC.begin("/cdcard", true)) {
    Serial.println("Card Mount Failed");
    return;
  testIO(SD_MMC);
  SD_MMC.end(); // cancel SD card mount
after program running, we will find "hello word" have wrote to txt file and saved SD card.
SD card use by "1BIT_SDMMC" work mode.
[Arduino source code for KC868-M16]-04 -Read / Write SD card arduino source code - by admin - 05-04-2023, 06:14 AM
