Template for KC868-A4 Tasmota
(05-24-2023, 01:52 AM)admin Wrote: for example, i use digital input-1 with a PIR sensor. you can connect with your float sensor.
define GPIO36 as Switch1
A configured PIR will not appear in the web UI in any form. To make it report like a sensor we need a rule that will send movement triggers to an MQTT topic.
SwitchMode1 1
SwitchTopic 0
Rule1 on Switch1#state=1 do publish stat/%topic%/PIR1 ON endon on Switch1#state=0 do Publish stat/%topic%/PIR1 OFF endon
Rule1 1
now when you short digital input-1 to GND or not short it.
you will have feedback message, in your Node-Red, you can received MQTT feedback message for INPUT state:
Thx aloooot for the help now i can start working on my node-red I'm using your bord to command my pool xD
its perfect =) continue with the great work .
Template for KC868-A4 Tasmota - by VascoTeixeira - 05-16-2023, 06:41 PM
RE: Template for KC868-A4 Tasmota - by admin - 05-17-2023, 12:40 AM
RE: Template for KC868-A4 Tasmota - by admin - 05-17-2023, 02:09 AM
RE: Template for KC868-A4 Tasmota - by admin - 05-23-2023, 10:40 PM
RE: Template for KC868-A4 Tasmota - by admin - 05-24-2023, 01:52 AM
RE: Template for KC868-A4 Tasmota - by VascoTeixeira - 05-24-2023, 01:01 PM
RE: Template for KC868-A4 Tasmota - by admin - 05-24-2023, 01:09 PM
