11-16-2023, 02:01 AM
(This post was last modified: 11-16-2023, 02:04 AM by airantoujc.)
Arduino settings below and hardware serial cpp changes attached
#define TX2 13
#define RX2 34
void modemHandler() {
String res;
SerialMon.println("========INIT========");
modem.init();
SerialMon.println("========SIMCOMATI======");
modem.sendAT("+SIMCOMATI");
modem.waitResponse(1000L, res);
res.replace(GSM_NL "OK" GSM_NL, "");
SerialMon.println(res);
res = "";
SerialMon.println("=======================");
SerialMon.println("=====Preferred mode selection=====");
modem.sendAT("+CNMP?");
if (modem.waitResponse(1000L, res) == 1) {
res = "";
SerialMon.println("=====Preferred selection between CAT-M and NB-IoT=====");
modem.sendAT("+CMNB?");
res = "";
String name = modem.getModemName();
SerialMon.println("Modem Name: " + name);
String modemInfo = modem.getModemInfo();
SerialMon.println("Modem Info: " + modemInfo);
for (int i = 0; i <= 4; i++) {
uint8_t network[] = {
2, /*Automatic*/
13, /*GSM only*/
38, /*LTE only*/
51 /*GSM and LTE only*/
SerialMon.printf("Try %d method\n", network[i]);
modem.setNetworkMode(network[i]);
delay(1000);
bool isConnected = false;
int tryCount = 60;
while (tryCount--) {
int16_t signal = modem.getSignalQuality();
SerialMon.print("Signal: ");
SerialMon.print(signal);
SerialMon.print(" ");
SerialMon.print("isNetworkConnected: ");
isConnected = modem.isNetworkConnected();
SerialMon.println(isConnected ? "CONNECT" : "NO CONNECT");
if (isConnected) {
break;
delay(500);
digitalWrite(LED_PIN, !digitalRead(LED_PIN));
// Set console baud rate
SerialMon.begin(38400);
delay(1000);
pinMode(LED_PIN, OUTPUT);
//modemPowerOn();
SerialMon.println("Wait...");
// Set GSM module baud rate
SerialAT.begin(UART_BAUD, SERIAL_8N1, RX2, TX2);
delay(3000);
SerialMon.println("Initializing modem...");
modemHandler();
digitalWrite(LED_PIN, LOW);
SerialMon.print("Modem Info: ");
SerialMon.println(modemInfo);
#if TINY_GSM_USE_GPRS
// Unlock your SIM card with a PIN if needed
if (GSM_PIN && modem.getSimStatus() != 3) { modem.simUnlock(GSM_PIN); }
#endif
#if TINY_GSM_USE_WIFI
// Wifi connection parameters must be set before waiting for the network
SerialMon.print(F("Setting SSID/password..."));
if (!modem.networkConnect(wifiSSID, wifiPass)) {
SerialMon.println(" fail");
delay(10000);
return;
SerialMon.println(" success");
#endif
#if TINY_GSM_USE_GPRS && defined TINY_GSM_MODEM_XBEE
// The XBee must run the gprsConnect function BEFORE waiting for network!
modem.gprsConnect(apn, gprsUser, gprsPass);
#endif
SerialMon.print("Waiting for network...");
if (!modem.waitForNetwork()) {
delay(10000);
return;
if (modem.isNetworkConnected()) { SerialMon.println("Network connected"); }
// GPRS connection parameters are usually set after network registration
SerialMon.print(F("Connecting to "));
SerialMon.print(apn);
if (!modem.gprsConnect(apn, gprsUser, gprsPass)) {
delay(10000);
return;
if (modem.isGprsConnected()) { SerialMon.println("GPRS connected"); }
#endif
// Make sure we're still registered on the network
if (!modem.isNetworkConnected()) {
SerialMon.println("Network disconnected");
if (!modem.waitForNetwork(180000L, true)) {
delay(10000);
return;
SerialMon.println("Network re-connected");
// and make sure GPRS/EPS is still connected
if (!modem.isGprsConnected()) {
SerialMon.println("GPRS disconnected!");
delay(10000);
return;
if (modem.isGprsConnected()) { SerialMon.println("GPRS reconnected"); }
#endif
#if TINY_GSM_USE_GPRS && not defined TINY_GSM_MODEM_HAS_GPRS
#undef TINY_GSM_USE_GPRS
#undef TINY_GSM_USE_WIFI
#define TINY_GSM_USE_GPRS false
#define TINY_GSM_USE_WIFI true
#endif
#if TINY_GSM_USE_WIFI && not defined TINY_GSM_MODEM_HAS_WIFI
#define TINY_GSM_USE_GPRS true
#define TINY_GSM_USE_WIFI false
#endif
my ifdef is using GSM GPRS
#define TX2 13
#define RX2 34
String res;
modem.init();
res = "";
res = "";
res = "";
2, /*Automatic*/
13, /*GSM only*/
38, /*LTE only*/
delay(1000);
int tryCount = 60;
if (isConnected) {
break;
delay(500);
delay(1000);
//modemPowerOn();
delay(3000);
modemHandler();
#endif
delay(10000);
return;
#endif
#endif
delay(10000);
return;
delay(10000);
return;
#endif
delay(10000);
return;
delay(10000);
return;
#endif
#endif
#endif
