Ok. Thanks for yor replies.
In regards if dimming I will be using KC868-D16+ LED driver But I would like to clarify the driver:
8. What kind of Kincony LED driver can I use for dimm 220v LED bulbs or incandescent ones?
9. What is the difference between "12V/24V 100W LED Dimmable Driver For KC868-D16" and "0 -10v Dimmable LED Drivers" when connecting it to KC868-D16+ ?
10. (different topic) What type of cables should I prepare my house for different types of esp32 sensors ? (door, presence, humidity temperature etc) Will CAT6a cable be ok?
11. What type of cables should I prepare my house for the wall light switches? Would CAT6a cable be ok or should I use YSLY 7x0.75mm for control and use NYY-J 5x1.5mm for the load only?
Thanks,
Erazer
Thanks,
Erazer
