07-26-2023, 01:44 PM
KC868-E16T Factory Original Firmware for Tuya App
07-26-2023, 11:53 PM
ok, when our team have free time, let remote button 1-16 support toggle relay 1-16. make a new firmware.
08-07-2023, 08:00 AM
(07-26-2023, 01:44 PM)Alpha21 Wrote:(07-25-2023, 08:53 AM)admin Wrote: do you must use tuya app at the same time? or just only use digital input and RF remote control? (07-26-2023, 11:53 PM)admin Wrote: ok, when our team have free time, let remote button 1-16 support toggle relay 1-16. make a new firmware. Any update with regards this? Much apprciated
08-21-2023, 02:10 AM
new firmware updated download at here:
https://www.kincony.com/forum/showthread.php?tid=3170
08-23-2023, 08:20 AM
here is video tour for you:
Witam wszystkich,
po zakupie urządzenia wgrałem oprogramowanie, a urządzenie nie komunikuje się przez Ethernet. Proszę pomóż mi.
01-09-2025, 11:24 PM
compare this photo as yours. you have not select item 1-3, please check it.
I erased the module with the "ERASE" command and then uploaded 4 files. The module does not communicate with the LAN. After uploading the "E16T-RF-Tuya.bin" file, the device connected to the router (192.168.1.200) but I cannot connect to it via a web browser. The "ping" command works correctly. UDP_SCAN_LIST does not detect it. Changing the computer did not change anything. Maybe it depends on the router's IP address? (192.168.1.254).
01-11-2025, 02:03 AM
this is not KCS firmware, not use by webpage. after download firmware, you can use tuya app, INPUT toggle OUTPUT and 433MHz remote directly.
01-11-2025, 06:46 AM
But after uploading:
KC868-E16T_tuya.nodemcu-32s.bin and the other three files E16T does not see the LAN I do not know what to install on this board since what is recommended does not work... |
« Next Oldest | Next Newest »
Users browsing this thread: |
1 Guest(s) |
