Connection to the Home Assistant app?
#21
(02-01-2025, 05:10 PM)wchpikus Wrote: hello i try to add kc868-a32 mqqt to HA but in config file i got errors..
mqtt:
- name: 'output-1'
unique_id: output-1
state_topic: 'server/8ae082ec66f37db231cf2b8f/state'
command_topic: 'server/8ae082ec66f37db231cf2b8f/set'
state_on: 1
state_off: 0
bad indentation of a sequence entry (141:8)
138 | - topic: "Esp32-rolety/connected"
139 |
140 | #Kincony hc868-a32
141 | mqtt:
configuration.yaml.
is any example working with 14.02 HA?
It could be syntax error on yaml now, but i am weak on the yaml files.
your command and state TOPIC is wrong, please check with our mqtt protocol document.
admin I downloaded the sample YAML config file here
https://www.kincony.com/forum/showthread.php?tid=2543
and the indentation in the file is not correct: there is an extra blank space before the lines I highlighted. I think this explains the error about the indentation.
wchpikus you should correct this, and then also replace 8ae082ec66f37db231cf2b8f with the serial of your own card.
for example, here is relay1 of KC868-A32:
mqtt:
   - name: 'a32-kcs-output-1'
     unique_id: a32-kcs-output-1
     state_topic: 'KC868_A32/08F9E08B1F58/STATE'
     command_topic: 'KC868_A32/08F9E08B1F58/SET'
     state_on: true
     state_off: false
replace by your own serial number, check INDEX webpage what serial number have showed.
3 Guest(s)
