04-10-2024, 01:19 PM
It seems I am too stupid to use the dimmer KC868-D8 with the firmware version 4.37
Flashing and so one was successful and now I started to test the dimmer keys.
I made the settings:
- Switcher Workmode: 1 Key
- Remember Last State: No (based on your last reply)
Connected K1+ with KCOM as a test:
![[Image: dimmer-connect.png]](https://i.postimg.cc/9X9vRyMT/dimmer-connect.png)
Behavior:
1. Long Press on the button => Normal behaviour the dimmer goes up and down as described ✅
2. If the light is on, then "short press" on the button => Normal behavior the dimmer value goes down to 0 ✅
3. If the light is off, then "short press" on the button => Faulty behavior the dimmer value does not change at all! ❌
My expectation is the same as in the video https://youtu.be/MdCBQl_y4f8?si=68JOT1UzzXkuaNfm&t=605
which means: "short press" when the lights are off should result in setting the dimmer to 99.
Anyone else with this problem?
Behavior:
