KC868-D16 - what's the max load(s)?
Some questions about KC868-D16.
First one - what is the maximum load [Watt] per channel and max summary for module?
Second one - what's the dimming type? Phase-cut dimming, Pulse Width Modulation, Resistance dimming or some else?
And additional little out of topic - can this module work directly with Tuya, without any additional Kincony's controller/gateway/etc?
Regards.
1: KC868-D16 not drive load directly, it need add dc 0-10v driver for DC12v/24V LED strip. so the MAX load [Watt] according to the "driver".
2. KC868-D16 is output dc 0-10v voltage signal.
3. sure, KC868-D16 is a tuya dimmer controller, use tuya app directly without other gateway.
(07-03-2024, 11:57 PM)admin Wrote: 1: KC868-D16 not drive load directly, it need add dc 0-10v driver for DC12v/24V LED strip. so the MAX load [Watt] according to the "driver".
Thank you for quick reply.
So, that module cannot control dimmable 230V LED bulbs directly itself?
Is there any other multi-channel module which can do that?
So, that module cannot control dimmable 230V LED bulbs directly itself? Yes, but add analog SSR is ok, then KC868-D16 can control AC220V lamp. here is link: https://shop.kincony.com/products/analog...-regulator
because the SSR control AC 0-220v output by analog input DC 0-10V
