I Need Help Kincony KC868-A8 Integration
Smile
Hello all,
I am working on a project that requires integrating Kincony's KC868-A8 relay controller into a custom automation system, and facing some challenges related to communication protocols, data handling, and device reliability;
  • Communication Protocols
  • Data Handling
  • Device Reliability
  • API/SDK Usage
I am eager to learn from the community's collective knowledge and experience. Any insights or suggestions would be greatly appreciated... Smile
Thanks in advance for my help....
KC868-A8 support HTTP, MQTT, TCP command protocol. you can chose protocol for integration according to your system structure.
we don't have SDK, but just check with protocol document is enough. here is KCS firmware for HTTP, MQTT, TCP protocol documents download: https://www.kincony.com/forum/forumdisplay.php?fid=40
(08-26-2024, 06:08 AM)admin Wrote: KC868-A8 support HTTP, MQTT, TCP command protocol. you can chose protocol for integration according to your system structure.
I will check it out, thanks for sharing this guideince....
you are welcome.
