Time control not working
Hi everyone,
I am having trouble configuring my device.
I want to set the relay to turn on at a specific time and perform several functions.
Here is a screenshot, but unfortunately it is not working.
Please help and advice.
if you timer can't work, you can do a system-restore action. or hold on "S2" button >10 seconds, will be RESET for board.
here is sample i set the time zone firstly, then make a IFTTT timer work 10:30AM for TURN ON relay1. you can test as by photo step by step.
(03-22-2024, 02:34 AM)admin Wrote: if you timer can't work, you can do a system-restore action. or hold on "S2" button >10 seconds, will be RESET for board.
Thank you, ive done all like you. But ok will reset board and will try.
(03-22-2024, 02:34 AM)admin Wrote: I found the problem. I set the board's timer to Chinese time and it works even though the board's clock shows Time Zone UTC+8. The timer works on Chinese time. Im going to factory reset board.
after restore its same, the problem is that when i set our time zone which is UTC+2 board dont show correct time any idea ?
you can set any UTC+x item, just let board's time as same as your COMPUTER's time is ok.
(03-23-2024, 11:58 AM)admin Wrote: you can set any UTC+x item, just let board's time as same as your COMPUTER's time is ok.
I have same problem,  i set utc +3  for worrking correctly, but the Board time is 6 or 5 hours ago. Please fix bug.
In Greece, the standard time is Eastern European Time (Greek:Eastern European Time; EET; UTC+02:00). Daylight saving time, which moves one hour ahead to UTC+03:00 is observed from the last Sunday in March to the last Sunday in October.
I have the same issue. Setting the NTP server to multiple different addresses or setting the my UTC does nothing and the time is not correct. This must be a code error. For me to get the correct time, I have to set UTC to UTC+8. I am in UTC -6. What is going on?
(09-11-2024, 01:51 PM)mobob Wrote: I have the same issue. Setting the NTP server to multiple different addresses or setting the my UTC does nothing and the time is not correct. This must be a code error. For me to get the correct time, I have to set UTC to UTC+8. I am in UTC -6.  What is going on?
I have now tried tihs on both the A4 and A6 boards with the latest firmware. Bot boards have the same issue. Setting the proper UTC time zone does not work properly. There must be something wrong with the calculations in the code
try the board time -5 (Daylight saving time)  or -6 hour ago from your current time. see my post.
