temperature sensor
hello engineer
I want to know how to connect humidity and temperature sensor to the A128  or kc868 server
there are sensor's pin define:
Red: DC5V
Black:GND
Yellow:humidity
White:temperature
KC868-A128: A1 and A2 is 0-5v dc analog input ports. A3 and A4 is 4-20mA analog input ports.
your sensor output signal is 0-5v dc. so your sensor RED and Black connect with 5V power supply. Yellow and White cable connect to A1 or A2 of A128 board.
Hello!
How and what is the code to integrate a senzor in Home Assistant via MQTT? Where I can found the proper documentation for this?
Thank you!
see here is MQTT document for KCS v2: https://www.kincony.com/forum/showthread.php?tid=3105
