KC868-E16T Factory Original Firmware for Tuya App
#21
(07-25-2023, 08:53 AM)admin Wrote: do you must use tuya app at the same time? or just only use digital input and RF remote control?
i need to simultaneously use tuya app and RF at the same time
ok, when our team have free time, let remote button 1-16 support toggle relay 1-16. make a new firmware.
(07-26-2023, 11:53 PM)admin Wrote: ok, when our team have free time, let remote button 1-16 support toggle relay 1-16. make a new firmware.
Any update with regards this? Much apprciated
new firmware updated download at here:
https://www.kincony.com/forum/showthread.php?tid=3170
here is video tour for you:
Witam wszystkich,
po zakupie urządzenia wgrałem oprogramowanie, a urządzenie nie komunikuje się przez Ethernet.
Proszę pomóż mi.
compare this photo as yours. you have not select item 1-3, please check it.
[Image: attachment.php?aid=2462]
I erased the module with the "ERASE" command and then uploaded 4 files.
The module does not communicate with the LAN.
After uploading the "E16T-RF-Tuya.bin" file, the device connected to the router (192.168.1.200) but I cannot connect to it via a web browser.
The "ping" command works correctly.
UDP_SCAN_LIST does not detect it.
Changing the computer did not change anything.
Maybe it depends on the router's IP address? (192.168.1.254).
this is not KCS firmware, not use by webpage. after download firmware, you can use tuya app, INPUT toggle OUTPUT and 433MHz remote directly.
But after uploading:
KC868-E16T_tuya.nodemcu-32s.bin
and the other three files E16T does not see the LAN
I do not know what to install on this board since what is recommended does not work...
