Time control not working
#21
I still have the same issue. Everything is setup correctly according with your tips and ifttt time is not working
here showed sensor tab.
(01-29-2025, 08:39 PM)klakier2121 Wrote: I still have the same issue. Everything is setup correctly according with your tips and ifttt time is not working
do you means you have set correct time zone, but IFTTT can't work? if YES, take screen photo of your IFTTT setting.
Time set correctly and nothig happens.
I have another question. Can I connect W5500 LAN controller to my A6 board?
what's your time zone set? if you can take a video of your problem send to whatsapp number: +86-15381188302 will be better.
you can try to connect w5500 with SPI bus, just i have not tested.
