hello, i have a question about the relay board
I watched YouTube and connected the relay controller to the app.
But when I press the switch on the app, there is no relay operation sound and the LED light does not turn on.
My board is old 8CH.
Please help me
take a photo which controller you are using.
please write your question in details.
(02-09-2025, 02:43 AM)admin Wrote: take a photo which controller you are using.
I have two controllers, H8B and H8W,
I watched kincony youtube to do the test.
I connected it to the app, but there's no LED light and relay operation sound.
There was a reaction in the datalog when I pressed the switch, so I checked it and it seems to be a normal response.
kincony cloud server stop use in 2024-12-31
https://www.kincony.com/forum/showthread.php?tid=5437
kincony smart home app is stop to use. the PC software or KBOX software also can work in locally.
(02-09-2025, 07:16 AM)admin Wrote: kincony cloud server stop use in 2024-12-31
We used the tuya app and also used ESP32 Tuya IoT Adapter V2
ok, if you use by tuya adapter v2, just do as this video:
https://youtu.be/zSOtzTXvUiI
make sure you have set the network mode = TCP Server using Vircom tool.
https://www.kincony.com/download/VirCom_5.33.zip
(02-09-2025, 12:24 PM)admin Wrote: ok, if you use by tuya adapter v2, just do as this video:
i saw that!
How do I set it up here? (picture)
(02-09-2025, 12:43 PM)admin Wrote: https://www.kincony.com/download/VirCom_5.33.zip
very thank you
How do I set it up here? (vircom)
yes, scan your device firstly.
