How to use channel 5,6,7,8
If only 4 channel can be used by ESP Home, is there any way to use channel 5,6,7,8 of AG8 module ?
download KCS v3 for AG8 controller is ok.
(04-23-2025, 11:05 PM)admin Wrote: download KCS v3 for AG8 controller is ok.
I tried that first,, using KCS interface I could try channels 1-4 (didnt tried others). Unfortunatelly I couldnt make homeassistant work with it. Is there any tutorial for that ?
Is there any way to use climate platform with KCS firmware just by indicating AC brand and model for example?
THanks
if use KCS v3 firmware for AG8, all 8 channel IR sender can by used. here is video tour: https://youtu.be/Lw0Mn_QbV9A
(04-24-2025, 11:56 PM)admin Wrote: if use KCS v3 firmware for AG8, all 8 channel IR sender can by used. here is video tour: https://youtu.be/Lw0Mn_QbV9A
Hi , thanks for reply.
But in this case we do need to leard code by code. Is there any way to use climate platform and only point to ir channel at AG8 ?
One more thing, I could not make it work with homeassistant. It is auto discovering, but did not add to device lists. Using 3.9.1 kcs and latest HA update.
1. if you want use ESPHome, ESPHome only support 4 channel IR sender for ESP32-S3 chip. Maybe in future, they will update for ESPHome.
2. you can integraet by mqtt for every IR signal manually.
