Automation for my new apartment
#21
Sorry not sure if i understood correctly the last part.
I understand that i dont need the switch board (https://www.kincony.com/how-to-use-switc...board.html) ? Is that correct ?
When i place my order is there any way we can have a call to make sure i order all the stuff i need (i can pay extra for the assistance if thats the case)
Best regards
1. you are right.
2. you can contact with whatsapp number: +86-15381188302
Finished my power distribution box finally
good job. just i thinkg you have not downloaded KCS v3 firmware to ESP32.
(08-30-2025, 08:41 AM)admin Wrote: good job. just i thinkg you have not downloaded KCS v3 firmware to ESP32.
dont recall the version but its configured in home assistant and everything works ok.
is there a way to make the lights dimmable ?
Best regards,
Razvan
relay controller only use for ON/OFF, if you want use for dimmable light, need add KC868-D16 dimmer controller + LED driver
