KC868-H32 +button switch module V4.43?
Hi
I have KC868-H32 (2020)  +button switch module for KC868-Hx .All worked perfect until i try  use MQTT for HA  ?
I update firmvare to 4.43   by  USB-RS232. and now switch module  doesnt  work- all lights  Smile
What can i do now? what the last firmware  to H32?  .V4.43 works only with H3xB ?
Where i can find last firmware for H32
thanks for help
v4.43 only work for KC868-H32B, not for H32(old version). give me your email, i send you H32 firmware, you can download it.
(04-30-2022, 11:21 PM)admin Wrote: v4.43 only work for KC868-H32B, not for H32(old version). give me your email, i send you H32 firmware, you can download it.
mawram@wp.pl
thanks
My home's system   2x H32  ,2xH16, 2x switch button terminal    (Hx old version)
I would like to use MQTT for feedback states in  HA.
Do I have to replace all relay controllers  with newer ones (H32B...or Server) , or can I upgrade the current system wanting to use MQTT for HA?
what the best solution? I use many wall switch connect by switch button terminal  to H16-32 .I don't need  wifi module. I use wire connection.
thanks for help
email have sent to you.
the best solution is use one KC868-Server add KC86H32BS+ KC868-E16.
so that your home assistant can install on the KC868-Server, KC868-H32BS for extend output, use E16 when relay is bad, it easy to replace and repaire, because E16's relay is removable.
old controller no new firmware for update for MQTT, because chip no memory space for update.
(05-02-2022, 12:36 AM)admin Wrote: email have sent to you.
can u please help me too? i have an old kc868 h32 with manual button module. now i would like to use it in homeassistant preference mqtt. is there a software update for the controller for this?
gr jeroen
controller: H868190900896
manual button: KC868-H8&32 Manual control Board REV1:1
if you are using KC868-H32,H32L,H32LW, these old version CPU not have enough memory for MQTT firmware.
MQTT only support by KC868-H32B,H32BS,H32B Pro.
