Uair
can we make scnce from alexa by Uair after integration with homeassistant??????????????
sure, if you integrate to home assistant, create "automation" in home assistant.
(07-04-2022, 10:10 PM)admin Wrote: sure, if you integrate to home assistant, create "automation" in home assistant.
can it work with kbox local without internet??????
kbox user for relay controller and dimmer, not for KC868-Uair, if you want to use by local network without internet:
1. use by home assistant, it work locally.
2. enable esphome http web service, so that you can use wifi ip address login by web browser in local network.
