KC868-AG ESP32 315/433Mhz or only 433Mhz?
Question
Hi Team, is the KC868-AG ESP32 both 315Mhz & 433Mhz? The Aliexpress listing says it's both 315Mhz & 433Mhz but I can't find any reference to 315Mhz in the documentation. Cheers!
Hello! KC868-AG use by 433MHz.
KC868-G use by 315M sender and 433M sender.
here are two different products.
(08-22-2022, 12:09 AM)admin Wrote: Hello! KC868-AG use by 433MHz.
Thank you, can I run ESPHome on the KC868-G?
no, KC868-G made by STM32 CPU. if you want to use ESPhome, you should chose KC868-AG, that made by ESP32 module.
(08-22-2022, 01:13 AM)admin Wrote: no, KC868-G made by STM32 CPU. if you want to use ESPhome, you should chose KC868-AG, that made by ESP32 module.
Thank you. Are you developing an ESP32 with 315Mhz in the future?
if you want to use 315M, just replace the 433M wireless module with 315M is ok. it's easy.
