08-29-2022, 11:58 PM
Sorry you misunderstood my query #67
I'm using the same 128 GB memory stick that we configured before and move the disk to it.
Due to home assistant crash and reinstall drivers and hkme assistant sgain the server usb ports came un activated as intial before.
I repeated the steps that you mentioned before to configure the usb port of rasspery pi but no success.
edit the boot config file (/boot/config.txt) and add:
dtoverlay=dwc2,dr_mode=host
Then reboot the Pi. But not able to use the built-in USB 2.0 ports as before.
Is it clear now? Do you understand?
