KC868-A16 ESPHome yaml for DHT11/ds18b20 RF
I am using ESPhome and home assistant, tried the below yaml using REV1.5 board but not sure how to get the temperature sensor and RF receiver/transmitter(already installed) working on HA.
Is my yaml correct? I am not sure about the pin number used, from the board i see the dht data cable is fixed at HT3.
Please help take a look at the yaml and also how to use with HA. Unable to find info for ESPHome and HA using KC868-A16.
remote_receiver:
  pin: 2
  dump: rc_switch
  # Settings to optimize recognition of RF devices
  tolerance: 50%
  filter: 250us
  idle: 4ms
  buffer_size: 2kb
remote_transmitter:
  pin: 15
  carrier_duty_percent: 100%
# Example configuration entry for sensor
  - platform: dht
    pin: 14
    temperature:
    humidity:
    update_interval: 10s
  # - platform: dallas
  #   pin: 14
  #   address: 0x1c0000031edd2a28
  #   name: "ds18b20-1"
here is pins define for KC868-A16:
DS18B20/DHT11/DHT21/WS2812 LED strip -1: 32
DS18B20/DHT11/DHT21/WS2812 LED strip -2: 33
DS18B20/DHT11/DHT21/WS2812 LED strip -2: 14
RF433MHz wireless receiver: 2
RF433MHz wireless sender: 15
I suggest you test step by step. such as test DHT11 firstly, delete your RF config firstly. when DHT is work well, then add RF module to ESPHome.
can you take a photo, how you wire your sensor and RF module with your KC868-A16 board.
(12-09-2022, 01:43 AM)admin Wrote: can you take a photo, how you wire your sensor and RF module with your KC868-A16 board.
(12-09-2022, 01:33 AM)admin Wrote: here is pins define for KC868-A16:
tried, remove rf, only left sensor but still not showing in HA or inside the esphome web server
  - platform: dht
    pin: 14
    temperature:
    humidity:
Resolved, i update the esphome via the lan network and though it was ok, but it is not.
I power off and on then use the usb option to install. Then it appear.
ok , great. update to newest version always a good way to solve problem.
