3kw heater control
I have a KC868-A16 and trying to get slow pwm or sigma delta running.
Im running home assistant so esp32 maybe would be the tightest integration.
Planning on controlling 3kw heaters via a SSR using one of the above techniques to regulate apparent power.
Thanks
sure, SSR can work with 3kw load. If it heats up, please add heat sink.
(05-05-2023, 09:54 PM)admin Wrote: sure, SSR can work with 3kw load. If it heats up, please add heat sink.
hi sorry not really the question i asked.
using SSR for the simple switched circuit using the A16 works great.
Is there anyway to vary the power using slow pwm or sigma delta using the A16
thanks
sorry, A16 not have analog output dc 0-10v option. other board have this port can use for adjust power output.
