CT Clamp small for 25am
any recommendation for a small clamp like the attached picture for 25amp or less for the M30?
do you want other range version?
(06-30-2024, 10:29 PM)admin Wrote: do you want other range version?
Hi, 3 questions please:
1- Any recommendation for 200A ct 35mm dia for m16 / m30.
2- For m16v2, what happens if ct clamp orientation is flipped? I mean the arrow, does it have to point to the electrical load?
3- what's the best way to order 100 or 200 m30 boards?
1- Any recommendation for 200A ct 35mm dia for m16 / m30. -->OK, i will consider
2- For m16v2, what happens if ct clamp orientation is flipped? I mean the arrow, does it have to point to the electrical load? -->it's same, no problem. it's AC signal.
3- what's the best way to order 100 or 200 m30 boards? --> you can contact with us by WhatsApp number: +86-15381188302
(06-30-2024, 05:31 PM)kiloptero Wrote: any recommendation for a small clamp like the attached picture for 25amp or less for the M30?
Not really! just looking for alternative for 32A and compatible with the m30. as I see the DL-CT03CL2.0 support at least 25a.
I will need to see the consume for a 63amp (whole house) with a RS485 meter and 2 for 32amp. The other will be used with DL-CT03CL2.0 because is less or equal of 25amp
Any recommendation?
we have 3 types of CT sensor:
DL-CT03CL2.0 aperture:5mm 0-20A
DL-CT08CL10-2000/1 aperture:8.4mm 0-60A
DL-CT08CHL-2000/1 aperture:14.5mm 0-100A
(07-01-2024, 10:32 PM)admin Wrote: Hi, 3 questions please:
for CT clamp arrow,
zmpt101b has L,N
so i though they must have same phase or something.
thanks for the clarification
zmpt101b use for detect VOLTAGE, not CURRENT.
(07-02-2024, 10:03 AM)admin Wrote: we have 3 types of CT sensor:
How to wire these clamps properly to M16 please? Solder 3,5 jack connector to them?
yes, just cut it , connect to board by two wires.
