Presence sensor issue
Hi, I bought Presence Sensor MTDx61 and after wiring it I always see Input turned ON.
Wiring is:
RED: 12v+
BLACK: 12v-
WHITE: 12v-
GREEN: INPUT 1
Is wiring OK? what's missing?
BLACK is GND, not use -12v. the sensor power supply is DC12V
GREEN and WHITE cable is dry contact output, not need connect with voltage , do you means "12V-" is GROUND?
can you take a photo how you wire.
here is video tour how to use presence sensor: https://youtu.be/bJBCDPORAh0
