KC868-AI - input as output HomeAssistant
Good morning,
in order to upgrade my home allarm system, I want to buy a KC868-AI. I have a question: I read that the dry contacts inputs can work as output with a KCS firmware; but can I use the input ad output also in Home Assistant?
I need one input as output in order to turn on the siren when one input is in allarm mode.
Thanks in advance.
Fausto
sure, KC868-AI INPUT can use in home assistant by ESPHome. the OUTPUT you need add another relay board, because of KC868-AI no OUTPUT on PCB, it's a INPUT module.
