Wired Water Leak Sensor on modul A16
dear admin,
I would like to connect the "Wired Water Leak Sensor" https://shop.kincony.com/products/wired-...282c&_ss=r to the KC868-A16 module and read the flood value in HomeAssistant in ESPHome.
> could you please publish the wiring diagram for the "Wired Water Leak Sensor" connection to A16?
> the sensor is connected to a digital input and is thus used as an active input in ESPHome?
regards
RED: +12V
BLACK: GND
GREEN: (OUTPUT) COMMON
BLUE: (OUTPUT) Normal Open signal
YELLOW: (OUTPUT) Normal Close signal
you can connect "Normal Open" or "Normal Close" wire to KC868-A16's digital input port.
