A8 keeps dying
I am using a A8 with my drapes.  I have NO inputs and just using the built in relays to trigger dry contacts.  I am running ESPHome.  The A8 I have doesn't have enough relays so I have two units side by side.  The are connected to a POE switch and each one is being powered via a POE to 12v splitter.  One of the units keeps dying.  It will not be pingable.  I have disabled the web server in esphome and I have disabled Bluetooth.  I reflashed several times.  After about 12 hours it will just stop responding.  I replaced it with another unit yesterday and today it continues to work with the same firmware. I believe this device is bad - but no idea how to debug and not interested I have too many other things going on.  This unit is believed to be bad.
you can download KCS firmware to test. download KCS firmware then directly to use.
