Firmware for KC868-A16v3 Board
Does anybody know wich firmware I must use for the KC868-A16v3 Board?
I loaded   KCS_KC868_A16_V2.2.12.zip  with USB and now the board does not work anymore.
Was it the wrong firmware?
As the name should indicate, that's v2 firmware. For the v3 board you need v3 firmware, KCS_A16V3_V3.something.
https://www.kincony.com/forum/showthread.php?tid=7783
Thank you.
I installed   KCS_A16V3_V3.8.0.zip
But the device does not work, no connection with lan.
See uploader-pic. Is this correct?
after download , MUST re power on of board.
Thumbs Up
Thank you. Problem solved
ok, good.
