Cross units communication
Hello
Assuming I have several units of T16M and/or B16M connected via Ethernet to the same net. Is it possible to configure them to operate together? For example, can I define a digital input of one unit to control output ports of another unit (of the same model type)? Which protocols / SW approaches allow such cooperative operation and which aren't?
Thanks,
Elad
sure, it's OK. you can download KCS v3 firmware to controller.
then define customize protocol in KCS. set by IFTTT, let controller-A input trigger THEN send customize command to controller-B by RS485 or TCP or HTTP protocol.
