Single Moment switch
I have a Kincony A16v3, with Home Assistant running on a Pi4.
I ran a Momentary Push Button Switch to a switch input on the A16v3.  I set up an automation where you press the switch, and it runs an automation.
Is there a way to run a different automation on the way you press the switch?  Like, if I hold the button down, it triggers a different automation?
If this exists, can you point me toward a tutorial?
Thank you
yes, you can use one button for different automation by "1-click", "2-click", "hold on" ways. if can set by KCS v3 firmware IFTTT webpage. this not need manager by home assistant. it can work locally.
