» Members: 10,188
» Latest member: Parke
» Forum threads: 4,264
» Forum posts: 21,143
There are currently 578 online users.
» 0 Member(s) | 550 Guest(s)
AhrefsBot, Applebot, AwarioBot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, Semrush, bot
SSD not visible for insta...
Forum: Pi5R16
Last Post: Verresen
7 hours ago
» Replies: 8
KC868-A16 and Tuya
Last Post: newdos
9 hours ago
» Replies: 8
KC868-AI mDNS problem
Forum: KC868-AI
10 hours ago
remember relay state
Forum: KC868-E16T
11 hours ago
» Replies: 9
N30 (KCS): energy counter...
Forum: N30
Yesterday, 11:12 PM
Bricked KC868-A16
Yesterday, 11:09 PM
» Replies: 7
KinCony G1 ESP32-S3 SIM76...
Forum: News
Yesterday, 11:09 PM
» Replies: 4
Current direction detecti...
Forum: N30
Last Post: dominique_manas@hotmail.com
Yesterday, 07:31 AM
» Replies: 4
KC868-A8 on Heat Pump for...
Last Post: marktuan
Yesterday, 03:17 AM
B32M maximum voltage
Last Post: felixandrea
Yesterday, 03:14 AM
  AG8 KCS firmware Wifi problem
Posted by: acztassi - 01-15-2025, 07:05 PM - Forum: KC868-AG / AG Pro / AG8 / Z1 - Replies (1)
hello, I had uploaded in my AG8 the firmware "KCS_KC868_AG_V2.2.8". But it appears to do not work. The ethernet does not start, the Wifi also don't start. How to is the right way to this board?
  KC868-A6 tasmota digital/analog input integration to Loxone
Posted by: sigituning - 01-15-2025, 02:10 PM - Forum: KinCony integrate with Loxone home automation - Replies (3)
can you provide info how to integrate http commands for loxone to read digital and analog inputs via tasmota firmware?
Or how we can read DI/AI inputs from this board in the loxone?
Can we use e.g. UDP commands somehow in the tasmota and loxone?
  KC868-A6 with waveshare LAN8720
Posted by: llast - 01-15-2025, 10:17 AM - Forum: KC868-A6 - Replies (3)
I am trying to setup KC868-A6 with LAN using waveshare lan8720 controller - I used the following configuration:
```ethernet:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
but I keep on getting the folowing error on esphome:
[11:11:41][C][ethernet:041]: Setting up Ethernet...
[11:11:41][V][esp-idf:000]: E (1589) esp.emac: emac_esp32_init(371): reset timeout
[11:11:41]
[11:11:41][V][esp-idf:000]: E (1589) esp_eth: esp_eth_driver_install(228): init mac failed
would you be able to support this configuration?
  Connect LD2420 Presence detection sensor to A8 controller.
Posted by: vijjav - 01-15-2025, 07:03 AM - Forum: KC868-A8 - Replies (5)
I want to connect my LD2420 presence detection sensor to A8 board. Please share me the pinout details.
LD2420 has RX, OT1, GND and 3v Pins
LD2420 24Ghz mmWave Radar Sensor — ESPHome
  [arduino code examples for A16v3]-12 digital INPUT trigger OUTPUT directly
Posted by: admin - 01-15-2025, 06:14 AM - Forum: KC868-A16v3 - No Replies
#include <PCF8574.h>     // Library to control the PCF8575 I/O expander
// Define I2C pins
#define SDA 9           // SDA pin
#define SCL 10           // SCL pin
TwoWire I2Cone = TwoWire(0);
PCF8574 pcf8574_I1(&I2Cone, 0x21, SDA, SCL);
PCF8574 pcf8574_I2(&I2Cone, 0x22, SDA, SCL);
PCF8574 pcf8574_R1(&I2Cone, 0x24, SDA, SCL);
PCF8574 pcf8574_R2(&I2Cone, 0x25, SDA, SCL);
  // Set pinMode to OUTPUT
pcf8574_R1.pinMode(P0, OUTPUT);
pcf8574_R1.pinMode(P1, OUTPUT);
pcf8574_R1.pinMode(P2, OUTPUT);
pcf8574_R1.pinMode(P3, OUTPUT);
pcf8574_R1.pinMode(P4, OUTPUT);
pcf8574_R1.pinMode(P5, OUTPUT);
pcf8574_R1.pinMode(P6, OUTPUT);
pcf8574_R1.pinMode(P7, OUTPUT);
pcf8574_R2.pinMode(P0, OUTPUT);
pcf8574_R2.pinMode(P1, OUTPUT);
pcf8574_R2.pinMode(P2, OUTPUT);
pcf8574_R2.pinMode(P3, OUTPUT);
pcf8574_R2.pinMode(P4, OUTPUT);
pcf8574_R2.pinMode(P5, OUTPUT);
pcf8574_R2.pinMode(P6, OUTPUT);
pcf8574_R2.pinMode(P7, OUTPUT);
pcf8574_I1.pinMode(P0, INPUT);
pcf8574_I1.pinMode(P1, INPUT);
pcf8574_I1.pinMode(P2, INPUT);
pcf8574_I1.pinMode(P3, INPUT);
pcf8574_I1.pinMode(P4, INPUT);
pcf8574_I1.pinMode(P5, INPUT);
pcf8574_I1.pinMode(P6, INPUT);
pcf8574_I1.pinMode(P7, INPUT);
pcf8574_I2.pinMode(P0, INPUT);
pcf8574_I2.pinMode(P1, INPUT);
pcf8574_I2.pinMode(P2, INPUT);
pcf8574_I2.pinMode(P3, INPUT);
pcf8574_I2.pinMode(P4, INPUT);
pcf8574_I2.pinMode(P5, INPUT);
pcf8574_I2.pinMode(P6, INPUT);
pcf8574_I2.pinMode(P7, INPUT);
  Serial.print("Init pcf8574_R1...");
  if (pcf8574_R1.begin()){
    Serial.println("PCF8574_R1_OK");
  }else{
    Serial.println("PCF8574_R1_KO");
  Serial.print("Init pcf8574_R2...");
  if (pcf8574_R2.begin()){
    Serial.println("PCF8574_R2_OK");
  }else{
    Serial.println("PCF8574_R2_KO");
  if (pcf8574_I1.begin()){
    Serial.println("pcf8574_I1_OK");
  }else{
    Serial.println("pcf8574_I1_KO");
  if (pcf8574_I2.begin()){
    Serial.println("pcf8574_I2_OK");
  }else{
    Serial.println("pcf8574_I2_KO");
  pcf8574_R1.digitalWrite(P0, HIGH);
  pcf8574_R1.digitalWrite(P1, HIGH);
  pcf8574_R1.digitalWrite(P2, HIGH);
  pcf8574_R1.digitalWrite(P3, HIGH);
  pcf8574_R1.digitalWrite(P4, HIGH);
  pcf8574_R1.digitalWrite(P5, HIGH);
  pcf8574_R1.digitalWrite(P6, HIGH);
  pcf8574_R1.digitalWrite(P7, HIGH);
  pcf8574_R2.digitalWrite(P0, HIGH);
  pcf8574_R2.digitalWrite(P1, HIGH);
  pcf8574_R2.digitalWrite(P2, HIGH);
  pcf8574_R2.digitalWrite(P3, HIGH);
  pcf8574_R2.digitalWrite(P4, HIGH);
  pcf8574_R2.digitalWrite(P5, HIGH);
  pcf8574_R2.digitalWrite(P6, HIGH);
  pcf8574_R2.digitalWrite(P7, HIGH);
uint8_t val1 = pcf8574_I1.digitalRead(P0);
uint8_t val2 = pcf8574_I1.digitalRead(P1);
uint8_t val3 = pcf8574_I1.digitalRead(P2);
uint8_t val4 = pcf8574_I1.digitalRead(P3);
uint8_t val5 = pcf8574_I1.digitalRead(P4);
uint8_t val6 = pcf8574_I1.digitalRead(P5);
uint8_t val7 = pcf8574_I1.digitalRead(P6);
uint8_t val8 = pcf8574_I1.digitalRead(P7);
uint8_t val9 = pcf8574_I2.digitalRead(P0);
uint8_t val10 = pcf8574_I2.digitalRead(P1);
uint8_t val11 = pcf8574_I2.digitalRead(P2);
uint8_t val12 = pcf8574_I2.digitalRead(P3);
uint8_t val13 = pcf8574_I2.digitalRead(P4);
uint8_t val14 = pcf8574_I2.digitalRead(P5);
uint8_t val15 = pcf8574_I2.digitalRead(P6);
uint8_t val16 = pcf8574_I2.digitalRead(P7);
if (val1==LOW) pcf8574_R1.digitalWrite(P0, LOW); else pcf8574_R1.digitalWrite(P0, HIGH);
if (val2==LOW) pcf8574_R1.digitalWrite(P1, LOW); else pcf8574_R1.digitalWrite(P1, HIGH);
if (val3==LOW) pcf8574_R1.digitalWrite(P2, LOW); else pcf8574_R1.digitalWrite(P2, HIGH);
if (val4==LOW) pcf8574_R1.digitalWrite(P3, LOW); else pcf8574_R1.digitalWrite(P3, HIGH);
if (val5==LOW) pcf8574_R1.digitalWrite(P4, LOW); else pcf8574_R1.digitalWrite(P4, HIGH);
if (val6==LOW) pcf8574_R1.digitalWrite(P5, LOW); else pcf8574_R1.digitalWrite(P5, HIGH);
if (val7==LOW) pcf8574_R1.digitalWrite(P6, LOW); else pcf8574_R1.digitalWrite(P6, HIGH);
if (val8==LOW) pcf8574_R1.digitalWrite(P7, LOW); else pcf8574_R1.digitalWrite(P7, HIGH);
if (val9==LOW) pcf8574_R2.digitalWrite(P0, LOW); else pcf8574_R2.digitalWrite(P0, HIGH);
if (val10==LOW) pcf8574_R2.digitalWrite(P1, LOW); else pcf8574_R2.digitalWrite(P1, HIGH);
if (val11==LOW) pcf8574_R2.digitalWrite(P2, LOW); else pcf8574_R2.digitalWrite(P2, HIGH);
if (val12==LOW) pcf8574_R2.digitalWrite(P3, LOW); else pcf8574_R2.digitalWrite(P3, HIGH);
if (val13==LOW) pcf8574_R2.digitalWrite(P4, LOW); else pcf8574_R2.digitalWrite(P4, HIGH);
if (val14==LOW) pcf8574_R2.digitalWrite(P5, LOW); else pcf8574_R2.digitalWrite(P5, HIGH);
if (val15==LOW) pcf8574_R2.digitalWrite(P6, LOW); else pcf8574_R2.digitalWrite(P6, HIGH);
if (val16==LOW) pcf8574_R2.digitalWrite(P7, LOW); else pcf8574_R2.digitalWrite(P7, HIGH);
  // Delay for 500 milliseconds
  delay(50);
arduino ino file download:
.zip   12-input-trigger-output.zip (Size: 1 KB / Downloads: 840)
.zip   12-input-trigger-output.ino.merged.zip (Size: 191.78 KB / Downloads: 769)
  [arduino code examples for A16v3]-11 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 01-15-2025, 06:12 AM - Forum: KC868-A16v3 - No Replies
* - SCL (clock) on pin IO10
* - SDA (data) on pin IO9
// Initialize the display using the software I2C method (SCL = IO10, SDA = IO9)
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0,  10, 9, U8X8_PIN_NONE);  // Screen rotation: U8G2_R0
void page1() {
  u8g2.begin();
  do {
    page1();
.zip   11-oled-ssd1306.zip (Size: 1.11 KB / Downloads: 834)
.zip   11-oled-ssd1306.ino.merged.zip (Size: 201.23 KB / Downloads: 806)
  [arduino code examples for A16v3]-10 RF433MHz sender
Posted by: admin - 01-15-2025, 06:10 AM - Forum: KC868-A16v3 - No Replies
  Example for different sending methods
  https://github.com/sui77/rc-switch/
#include <RCSwitch.h>
  Serial.begin(9600);
  // Transmitter is connected to Arduino Pin #10
  mySwitch.enableTransmit(18);
  // Optional set protocol (default is 1, will work for most outlets)
  // mySwitch.setProtocol(2);
  // Optional set pulse length.
  // mySwitch.setPulseLength(320);
  // Optional set number of transmission repetitions.
  // mySwitch.setRepeatTransmit(15);
  /* See Example: TypeA_WithDIPSwitches */
  mySwitch.switchOn("11111", "00010");
  mySwitch.switchOff("11111", "00010");
  /* Same switch as above, but using decimal code */
  mySwitch.send(5393, 24);
  mySwitch.send(5396, 24);
  /* Same switch as above, but using binary code */
  mySwitch.send("000000000001010100010001");
  mySwitch.send("000000000001010100010100");
  /* Same switch as above, but tri-state code */
  mySwitch.sendTriState("00000FFF0F0F");
  mySwitch.sendTriState("00000FFF0FF0");
  //delay(20000);
.zip   10-RF433M-sender.zip (Size: 664 bytes / Downloads: 839)
.zip   10-RF433M-sender.ino.merged.zip (Size: 181.71 KB / Downloads: 829)
  [arduino code examples for A16v3]-09 RF433MHz decode
Posted by: admin - 01-15-2025, 06:08 AM - Forum: KC868-A16v3 - No Replies
  Simple example for receiving
  Serial.begin(9600);
  mySwitch.enableReceive(digitalPinToInterrupt(8));
  if (mySwitch.available()) {
    Serial.print("Received ");
    Serial.print(" / ");
    Serial.print("bit ");
    Serial.print("Protocol: ");
    mySwitch.resetAvailable();
.zip   9-RF433M-decode.zip (Size: 451 bytes / Downloads: 776)
.zip   9-RF433M-decode.ino.merged.zip (Size: 181.08 KB / Downloads: 814)
  [arduino code examples for A16v3]-08 Ethernet W5500 chip work with TCP Server mode
Posted by: admin - 01-15-2025, 06:06 AM - Forum: KC868-A16v3 - Replies (2)
* received from a client.
* Hardware connections:
* - CLK: GPIO42
* - MOSI: GPIO43
* - MISO: GPIO44
* - CS: GPIO41
* - RST: GPIO1
* - INT: GPIO2
* Subnet Mask: 255.255.255.0
* Gateway: 192.168.3.1
* DNS: 192.168.3.1
#include <SPI.h>
#include <Ethernet.h>
#define W5500_CS_PIN  15
#define W5500_RST_PIN 1
#define W5500_INT_PIN 2
#define W5500_CLK_PIN 42
#define W5500_MOSI_PIN 43
#define W5500_MISO_PIN 44
EthernetServer server(4196);
  while (!Serial) {
  Ethernet.init(W5500_CS_PIN);
  Serial.print("IP Address: ");
  server.begin();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        server.write(c);
    client.stop();
.zip   8-Ethernet-W5500.zip (Size: 1.23 KB / Downloads: 876)
.zip   8-Ethernet-W5500.ino.merged.zip (Size: 188.94 KB / Downloads: 833)
  [arduino code examples for A16v3]-07 how to DS3231 RTC clock
Posted by: admin - 01-15-2025, 06:04 AM - Forum: KC868-A16v3 - No Replies
* DS3231 RTC with Arduino
* Hardware Connections:
* - SDA: GPIO 9
* - SCL: GPIO 10
#include <DS3231.h>
#include <Wire.h>
typedef struct
  byte month;
  byte day;
  byte hour;
  byte minute;
  byte second;
} MY_DATE_STR;
#define OPEN_RLY_DATA    26
#define OPEN_RLY_MONTH   4
#define CLOSE_RLY_DATA   2
#define CLOSE_RLY_MONTH  5
// Define pin connections
#define SDA_PIN   9
#define SCL_PIN   10
bool h12Flag;
bool pmFlag;
static bool bCentury = false;
static void PrintfCurTime()
  Serial.print(year);
  Serial.print("-");
  Serial.print("-");
  Serial.print(" ");
  Serial.print(":");
  Serial.print(":");
static void GetSerialCmd()
  if (Serial.available() > 0)
    delay(100);
    while (num_read--)
  else return;
  serial_cmd_rcv.trim();
    PrintfCurTime();
    return;
  Serial.print("D index: ");
  Serial.print(indexof_d);
  Serial.print(" T index: ");
  Serial.println(indexof_t);
    return;
  rtc.setDate(my_date_str.day);
  Serial.println("Time set.");
  PrintfCurTime();
  while (Serial.read() >= 0) {}
  GetSerialCmd();
.zip   7-DS3231-RTC.zip (Size: 1.56 KB / Downloads: 843)
.zip   7-DS3231-RTC.ino.merged.zip (Size: 191.07 KB / Downloads: 809)
