MT4 ESPHome yaml for home assistant without tuya
  friendly_name: MT4
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
web_server:
  port: 80
globals:
  - id: motor1_direction
    type: int
    restore_value: true
    initial_value: '0'
  - id: motor1_speed_value
    type: float
    restore_value: true
    initial_value: '0.5'
  - id: motor2_direction
    type: int
    restore_value: true
    initial_value: '0'
  - id: motor2_speed_value
    type: float
    restore_value: true
  - id: motor3_direction
    type: int
    restore_value: true
    initial_value: '0'
  - id: motor3_speed_value
    type: float
    restore_value: true
  - id: motor4_direction
    type: int
    restore_value: true
    initial_value: '0'
  - id: motor4_speed_value
    type: float
    restore_value: true
output:
  # Motor 1
    pin: GPIO39
    pin: GPIO46
  - platform: ledc
    pin: GPIO9
    frequency: 1000Hz
  # Motor 2
    pin: GPIO11
    pin: GPIO10
  - platform: ledc
    pin: GPIO12
    frequency: 1000Hz
  # Motor 3
    pin: GPIO13
    pin: GPIO47
  - platform: ledc
    pin: GPIO14
    frequency: 1000Hz
  # Motor 4
    pin: GPIO48
    pin: GPIO45
  - platform: ledc
    pin: GPIO21
    frequency: 1000Hz
script:
  # Motor 1
  - id: motor1_forward
    then:
      - output.turn_on: motor1_in1
      - output.turn_off: motor1_in2
      - output.set_level:
          level: !lambda "return id(motor1_speed_value);"
  - id: motor1_reverse
    then:
      - output.turn_off: motor1_in1
      - output.turn_on: motor1_in2
      - output.set_level:
  - id: motor1_stop
    then:
      - output.set_level:
          level: 0%
  # Motor 2
  - id: motor2_forward
    then:
      - output.turn_on: motor2_in1
      - output.turn_off: motor2_in2
      - output.set_level:
          level: !lambda "return id(motor2_speed_value);"
  - id: motor2_reverse
    then:
      - output.turn_off: motor2_in1
      - output.turn_on: motor2_in2
      - output.set_level:
  - id: motor2_stop
    then:
      - output.set_level:
          level: 0%
  # Motor 3
  - id: motor3_forward
    then:
      - output.turn_on: motor3_in1
      - output.turn_off: motor3_in2
      - output.set_level:
          level: !lambda "return id(motor3_speed_value);"
  - id: motor3_reverse
    then:
      - output.turn_off: motor3_in1
      - output.turn_on: motor3_in2
      - output.set_level:
  - id: motor3_stop
    then:
      - output.set_level:
          level: 0%
  # Motor 4
  - id: motor4_forward
    then:
      - output.turn_on: motor4_in1
      - output.turn_off: motor4_in2
      - output.set_level:
          level: !lambda "return id(motor4_speed_value);"
  - id: motor4_reverse
    then:
      - output.turn_off: motor4_in1
      - output.turn_on: motor4_in2
      - output.set_level:
  - id: motor4_stop
    then:
      - output.set_level:
          level: 0%
button:
  - platform: template
    on_press:
      - globals.set:
          value: '1'
      - script.execute: motor1_forward
    on_press:
      - globals.set:
          value: '-1'
      - script.execute: motor1_reverse
    on_press:
      - globals.set:
          value: '0'
      - script.execute: motor1_stop
    on_press:
      - globals.set:
          value: '1'
      - script.execute: motor2_forward
    on_press:
      - globals.set:
          value: '-1'
      - script.execute: motor2_reverse
    on_press:
      - globals.set:
          value: '0'
      - script.execute: motor2_stop
    on_press:
      - globals.set:
          value: '1'
      - script.execute: motor3_forward
    on_press:
      - globals.set:
          value: '-1'
      - script.execute: motor3_reverse
    on_press:
      - globals.set:
          value: '0'
      - script.execute: motor3_stop
    on_press:
      - globals.set:
          value: '1'
      - script.execute: motor4_forward
    on_press:
      - globals.set:
          value: '-1'
      - script.execute: motor4_reverse
    on_press:
      - globals.set:
          value: '0'
      - script.execute: motor4_stop
number:
    min_value: 0
    max_value: 100
    step: 1
    optimistic: true
    restore_value: true
    initial_value: 50
    set_action:
      - globals.set:
          value: !lambda "return x / 100.0;"
      - if:
          condition:
            lambda: "return id(motor1_direction) == 1;"
          then:
      - if:
          condition:
            lambda: "return id(motor1_direction) == -1;"
          then:
    min_value: 0
    max_value: 100
    step: 1
    optimistic: true
    restore_value: true
    initial_value: 50
    set_action:
      - globals.set:
      - if:
          condition:
            lambda: "return id(motor2_direction) == 1;"
          then:
      - if:
          condition:
            lambda: "return id(motor2_direction) == -1;"
          then:
    min_value: 0
    max_value: 100
    step: 1
    optimistic: true
    restore_value: true
    initial_value: 50
    set_action:
      - globals.set:
      - if:
          condition:
            lambda: "return id(motor3_direction) == 1;"
          then:
      - if:
          condition:
            lambda: "return id(motor3_direction) == -1;"
          then:
    min_value: 0
    max_value: 100
    step: 1
    optimistic: true
    restore_value: true
    initial_value: 50
    set_action:
      - globals.set:
      - if:
          condition:
            lambda: "return id(motor4_direction) == 1;"
          then:
      - if:
          condition:
            lambda: "return id(motor4_direction) == -1;"
          then:
yaml file download:
.txt   HA_4_motor.txt (Size: 9 KB / Downloads: 13)
