» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 81 online users.
» 0 Member(s) | 61 Guest(s)
Amazonbot, AwarioBot, Baidu, Crawl, PetalBot, Semrush, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  Apply free sample of KinCony IoT product - Youtube channel
Posted by: solutionfinder - 03-07-2024, 04:50 PM - Forum: Apply for free sample product - Replies (1)
I am applying for a free sample of Kincony product:- KC868-A4.
I have a YouTube channel regarding Electronic project education link:- https://www.youtube.com/@SolutionFinder
recent project development artificial indri is a device which helps to communication for paralyzed & hospitalized person.
https://youtube.com/shorts/t2MTlgr7StU?s..._KMFtD7xVc
also work as a freelance for product development consultancy to college students and tech companies.
work sample for home automation:-  https://youtube.com/shorts/farjTntdv60?s...0SVlp5KzIM
  KC868-A8 only with standard tasmota firmware possible
Posted by: DieterN - 03-07-2024, 03:26 PM - Forum: KC868-A series and Uair Smart Controller - Replies (6)
Hello all
I have flashed my KC868-A8 with Tasmota32.de fw.(https://tasmota.github.io/install/)
it works.
When I will flah the KC868-A8 firmware(KC868-A8-Tasmota-firmware.bin) with this tool,
I get an error like this:
and the board has no function.
Then i use the tasmota.de fw again, flash works but without
Configuration - Configure PCF8574  menu.
So i cant use the relais
Please help.
best regards
  LCD I2C not working
Posted by: Wickfut - 03-07-2024, 05:04 AM - Forum: KC868-A16 - Replies (2)
Are there any instructions on fitting a 20 x 4 I2C LCD display?
I've never had a problem using these displays with an ESP32, but I cannot get it to work via the I2C extender port on the KC868-A8M
TIA
  use of I2C connection
Posted by: Gerrit - 03-06-2024, 02:41 PM - Forum: KC868-AP / ADR - Replies (1)
Is it possible to use the white I2C plug on the kc868-ap board. If yes to what gpio numbers are the pins connected?
I would like to use this to connect pushbuttons via a IC bus interface as remotely I do not have enough wires to connect all the wall pushbuttons directly to the inputs of thet board.  I use  esphome
  KC868-D16 16 CH through Siemens logo 8.3
Posted by: onik_serj - 03-06-2024, 12:09 PM - Forum: DIY Project - Replies (2)
Good afternoon!
I can control KC868-D16 16 CH using Siemens Logo 8.3
and KC868-D16 16 CH 230 volt lamps?
My entire automation is built on a Siemens Logo 8.3 controller and all the lights work on 230 volts.
I want to leave the old switches that are connected to Siemens Logo 8.3 but control the KC868-D16
  How to use SN-SR04T Sensor
Posted by: mvtech2430 - 03-06-2024, 06:57 AM - Forum: KC868-A4S - Replies (1)
Hello , can i use SN-SR04T Sensor please see picture.
[Image: JSN-SR04T.jpg]
pin is GND VCC TRIG ECHO
HOW CAN I USE IT IN A4S or A8 Board
diagram using esp32
[Image: ESP32-Ultrasonic-Sensor-Wiring-Fritzing-...=all&ssl=1]
  AM2301
Posted by: Vaughan2024 - 03-06-2024, 03:07 AM - Forum: KC868-A8 - Replies (5)
Hi I wanted to add the AM2301 temperature and humidity sensor.
Is there an example of the code to add this type of sensor?
  H16b-mqtt
Posted by: ahmedwizza1 - 03-05-2024, 04:32 PM - Forum: News - Replies (1)
hello engineer
can you please help me? I need to config H16b
How can we do that?
any way send me the code or nod red file config.
  A8 lost network connection via LAN
Posted by: a.demenev@limeup.ru - 03-04-2024, 06:02 PM - Forum: KC868-A8 - Replies (20)
Hi all!
i integrate A8 to my ventilation system, it works fine, BUT!!!! A8 lost network connection via LAN every 10-40 minutes...
after restart connection establishing in few seconds.
https://youtube.com/shorts/jyNo9KttSPs?s...OHdtjRSwSU
Any ideas?
PS: yes, i know, i need some switches in this construction - they a planned and will be installed  soon
Question KC868-H32B plastic holder locks
Posted by: stybyk - 03-04-2024, 11:47 AM - Forum: KC868-HxB series Smart Controller - Replies (1)
When I bought KC868-H32B there was some plastic holders  in the package.
I incidentaly lost them.
I need somehow lock the box on the DIN rail.
Is here anyone who can share me 3d print file for that holders ?
