» Members: 10,107
» Latest member: eminent
» Forum threads: 4,256
» Forum posts: 21,084
There are currently 325 online users.
» 0 Member(s) | 304 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, Yandex, bot
m16v2 energy meter - cali...
3 hours ago
» Replies: 15
oCBot: KC868-A6/A16 as a ...
Last Post: oCBot
Yesterday, 01:32 PM
N20 Energy RS485 Modbus P...
Forum: N20
Yesterday, 12:43 PM
Getting inconsistent/wron...
Yesterday, 12:40 PM
KC868-HAv2 phantom press ...
Forum: KC868-HA /HA v2
Last Post: phrfpeixoto
09-29-2026, 01:57 AM
KC868-A6 Analog inputs
Last Post: Tomas4289
09-28-2026, 12:57 PM
N60/N30/N20/N10 PC softwa...
Forum: N10
09-28-2026, 12:49 PM
» Replies: 13
getting the A8A inputs to...
Forum: Development
09-28-2026, 08:38 AM
Best way to read from N30
Forum: N30
09-27-2026, 12:20 AM
extend KC868-A16v3
Last Post: bitet96717
09-24-2026, 06:41 AM
  on relays via modbus rs485
Posted by: 31marlosouza - 06-20-2024, 02:57 AM - Forum: KC868-A6 - Replies (7)
Olá, estou com dificuldade para ativar os relés da placa KC868 - através do pool modbus consigo ler as entradas analógicas, ler as entradas digitais, mas não consigo ativar os relés. Você poderia me enviar a documentação.
  433MHz remote_receiver
Posted by: deltabridge - 06-19-2024, 09:54 PM - Forum: KC868-A8S - Replies (3)
I am using ESPHome 2024.5.5 on the KC868-A8S device. After uploading the firmware that includes the remote_receiver component on GPIO16 for 433 MHz receiving module, the device becomes unresponsive and the web dashboard returns ERR_CONNECTION_REFUSED. Interestingly, when the remote_receiver component is not included, everything functions as expected.
Any ideas about that? Thank you!
  platform: ESP32
web_server:
  port: 80
ota:
#remote_receiver:
#  pin: GPIO16
#  dump: all
#  tolerance: 50%
#  filter: 250us
#  idle: 2ms
#  buffer_size: 2kb
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  - id: 'pcf8574_hub_in_1' # for input channel 9-16
# Individual outputs
      pcf8574: pcf8574_hub_out_1
output:
  - platform: ledc
    pin: GPIO2
rtttl:
  output: buzzer_output
light:
  - platform: fastled_clockless
    chipset: WS2812B
    pin: GPIO12
    num_leds: 1
    rgb_order: GRB
    default_transition_length: 0s
    restore_mode: ALWAYS_OFF
  A16 rs485 problem
Posted by: Psix_anp - 06-19-2024, 09:05 PM - Forum: KC868-A16 - Replies (9)
Hi!
Help me pls for a16
not working relay after 8relay on rs485
- platform: modbus_controller
    address: 0  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 1  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 2  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 3  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 4  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 5  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 6  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 7  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 8  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 9  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 10  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 11  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 12  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 13  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 14  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
    address: 15  # 0:relay1  1:relay2 ......
    register_type: coil
    bitmask: 1
address 10,11 etc not working
I can switch only 8 relays? my hardware A16
  How to connect SMOKE DETECTOR SENSOR with KC868-A64?
Posted by: jigneshk5 - 06-19-2024, 04:50 PM - Forum: KC868-A64 - Replies (17)
Hi, how to connect Smoke sensor (https://www.kincony.com/smoke-detector-sensor.html) with KC868-A64.
These are the pins present in smoke sensor:
RED: 12V
BLACK:GND
WHITE: COM
ORANGE: Normal open
YELLOW: Normal close
I have uploaded KCS_KC868_A64_v1.0.27 firmware in the controller. What is the MQTT topic for receiving data from digital pins?
  how to replace ESP32 large memory module for KinCony ESP32 Controller
Posted by: admin - 06-18-2024, 12:18 PM - Forum: KC868-A series and Uair Smart Controller - No Replies
this video replace ESP32-WROOM-32 by ESP32-WROOM-32E N16R2 for KinCony KC868-A8S board. it have PSRAM with ESP32. just make sure not need GPIO16 when you need to use PSRAM. So we have removed U17 chip, so that cut the ESP32 GPIO16 circuit.
here is arduino code for testing PSRAM and all hardware information for ESP32:
arduino source code download:
.zip   test-psram.zip (Size: 596 bytes / Downloads: 784)
#include <Arduino.h>
//Use this code to init the pSARM
// 打印 Arduino 库的版本信息
Serial.println("Arduino 库版本");
Serial.println(ESP_ARDUINO_VERSION);
   // 获取 Flash 大小(以字节为单位)
  uint32_t flashSize = ESP.getFlashChipSize();
  Serial.printf("Flash Size: %u bytes\n", flashSize);
  // 获取 PSRAM 的大小(以字节为单位)
  uint32_t psramSize = ESP.getPsramSize();
  Serial.printf("PSRAM Size: %u bytes\n", psramSize);
  // 获取剩余内存
  uint32_t freeMemory = ESP.getFreeHeap();
  Serial.printf("Free Memory: %u bytes\n", freeMemory);
   // 获取总内存
  uint32_t Totalheap = ESP.getHeapSize();
  Serial.printf("Total heap: %u bytes\n", Totalheap);
   // 获取 PSRAM 剩余内存
  uint32_t FreePSRAM = ESP.getFreePsram();
  Serial.printf("Free PSRAM: %u bytes\n", FreePSRAM);
void loop() {}
  START A PROJECT
Posted by: Nobleben80 - 06-17-2024, 09:55 PM - Forum: Apply for free sample product - Replies (1)
Dear Kincony Team.
i am a project engineer in automation engineering. i came across your products from youtube, and i am amazed with the profiling and ability of your product in handling facility automation.
I would like to get a free kit of your products to integrate it on my prospecting project (smart home installation on a duplex building) in nigeria.
These will enable me to become conversant with your products, use it on subsequent upcoming projects and also market it to client as a better automation product.
Below is my detail
Ogwo Noble-Ben Chukwuma
Project Engineer and Consultant at Mytric Waves
Tel and WhatsApp +2348063696900
ncogwo@gmail.com
I look for to hear from you. And also join your team
Sincerely.
Ogwo N.c
  Error on ESPHOME Official Config?
Posted by: tolbier - 06-17-2024, 08:29 PM - Forum: KC868-A series and Uair Smart Controller - Replies (5)
Is it possible that addresses for input channels on Kincony868 A16 were exchanged on official configuration on esphome?
https://devices.esphome.io/devices/KinCo...figuration
I was testing my new device and it surprised me that adresses were exchanged
This is my configuration for input addresses
    address: 0x21
  ENQUIRE ON PROSPECTED SMART HOME PROJECT
Posted by: Nobleben80 - 06-17-2024, 04:47 PM - Forum: DIY Project - Replies (1)
I'm building a new smart home and is prospecting to use KinCony products for the smart controls that will offer me the following features:
- Smart control of devices via ethernet, website, mobile app, wifi and bluetooth, Alexa and home assistance on remote base. Though, I will also use cable for reliability and efficiency.
QUESTIONS:
- Can i integrate smart touch wall switches as a second level control and alternative switch for designated gadget like ceiling led lighting point for manual control?
- In case of KC868 server goes down or hanged. Can kincony manual switch work effectively.
- Can i assign IP address to the kincony server from my home router network without using the sim card, so that it can access internet from my home internet router.
- Can i integrate my water pump level switch to the controller to control the pumping for water to the reservoir.
- Can i integrate a physical timer switch to control designated output for designated gadget or do you have a software that can take care of the timing of some output/terminal from the server.
BUILDING:
- Five Bedroom duplex with two sitting room, one kitchen and control room in Nigeria.
- 80 bulbs. some paired together. I will also use smart touch wall switches to manually switch off/on the lights as a second level control.
- 2 doors sensors with remote access to lock and unlock.
- Temperature sensors and smoke dictators
-  What component will satisfy all the requirements in building the kincony smart distribution box?
- 15kw Solar energy powered
I await for your feedback and look forward to work with you and also publish my work on your youtube and other social media channels
Many Thanks.
  Authentication failure
Posted by: Auxinne Paul - 06-17-2024, 12:16 PM - Forum: KC868-A8S - Replies (6)
Hello Sir, thanks for good work. I use your boards KC868-A8S, I have like 5 of them but I have problems with  "authentication expired"' that happens on home assistant randomly after a while. Could you please help me prevent it?
  Problem uploasing esphome firmware to KC868-A16
Posted by: tolbier - 06-17-2024, 09:14 AM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
Hello:
I've got two KC868-A16 and now I'm trying to upload the firmware, but it replies me with an error on Erasing:
[Image: 1cWhkAAAidMM10YSGU9ZfCgdmg_iD7c_u=w800-h909-iv1]
It keeps for a Long time and it returns a TimeOut error
Also, I've been trying with the ESP_FLASHER tool with similar result:
[Image: 1z2ES6ctJv1Fz8exKOpQUf_LZ2GobMoCO=w800-h909-iv1]
I tried with both cards and, the result is the same
Also I've been trying to upload it pushing Reset and Download Buttons, with no different result
I was trying tou upload from a Fedora 39 and also from a MacOS (Silicon M3)
any idea what is going on?
Thank you
