» Members: 10,117
» Latest member: Clubh19biz
» Forum threads: 4,257
» Forum posts: 21,092
There are currently 107 online users.
» 0 Member(s) | 89 Guest(s)
Baidu, Bing, Bytespider, Crawl, PetalBot, Semrush, Yandex, bot
KC868-A16 ethernet work w...
5 hours ago
» Replies: 31
Update to latest esphome
Last Post: Elgatoguiri
11 hours ago
» Replies: 4
B32M maximum voltage
Yesterday, 11:52 AM
» Replies: 4
m16v2 energy meter - cali...
10-02-2026, 11:50 AM
» Replies: 15
oCBot: KC868-A6/A16 as a ...
Last Post: oCBot
10-01-2026, 01:32 PM
N20 Energy RS485 Modbus P...
Forum: N20
10-01-2026, 12:43 PM
Getting inconsistent/wron...
10-01-2026, 12:40 PM
KC868-HAv2 phantom press ...
Forum: KC868-HA /HA v2
Last Post: phrfpeixoto
09-29-2026, 01:57 AM
KC868-A6 Analog inputs
Last Post: Tomas4289
09-28-2026, 12:57 PM
N60/N30/N20/N10 PC softwa...
Forum: N10
09-28-2026, 12:49 PM
» Replies: 13
  Binary Inputs 9-15 turn off with 1-8
Posted by: dockside - 05-16-2024, 08:20 PM - Forum: KC868-A16 - Replies (7)
Used ESPHome to configure Digital Inputs. However both inputs 8 & 16 turn off when shorting input 16.  Same with inputs 9 & 15 when shorting input 15. Same with all inputs from 16 down to 9, that is inputs 8 down to 1 also turn off. My KC868-A16 board is at REV 1.6 and log information attached.
Thanks for the help.
Ted
  AM2301
Posted by: milan.net - 05-14-2024, 03:32 PM - Forum: KC868-A8S - Replies (8)
Hello, I'm verry interested in this board( the v2 version)
I have  2 questions.
I need to use 2x AM2301 sensors, is it possible to use them with this board?
Which poe expansion board do I need to add to this board to use poe directly?
  Kc868-AM and sensors
Posted by: fdcemb5 - 05-14-2024, 02:31 PM - Forum: KC868-AM - Replies (4)
Where can I get yaml configuration file for esphome for the diagram attached
  KC868-AM with DS18B20
Posted by: fdcemb5 - 05-14-2024, 12:06 PM - Forum: KC868-AM - Replies (1)
Your ESphome yaml file example for KC868-AM does not show for DS18B20 sensor, how do add configuration entries for temperature sensors
  KC868 server
Posted by: fdcemb5 - 05-14-2024, 12:00 PM - Forum: KC868-Server Raspberry Pi4 local server - Replies (3)
if I connect DS18B20/DHT11/21 Temperature and humidity sensor to these pins, how do I make it appear in Home Assistant since I cannot write Arduino code on KC868 server
GPIO-1: GPIO4
GPIO-2: GPIO5
GPIO-3: GPIO18
GPIO-4: GPIO19
  Board Boot Error
Posted by: corkers - 05-14-2024, 06:28 AM - Forum: KC868-A16 - Replies (15)
Hi I have an A16 v1.5 board that will not flash.
From doing some reading this is a fatal error....
  Tuya adapter V2 arduino source code - RS485 relay controller KC868-H32BS
Posted by: admin - 05-14-2024, 02:18 AM - Forum: KC868-ATC / Tuya adapter V2 - Replies (8)
This is sample demo let RS485 digital output device (KinCony KC868-H32BS controller) can work with Tuya app by internet.  you can let your own RS485 relay board add to Tuya app.
added Tuya adapter v2, relay board will support alexa or Google home speaker for voice control directly.
arduino source code download:
.zip   Tuya_AdapterV2_RS485_Relay.zip (Size: 2.63 KB / Downloads: 894)
#include <ModbusMaster.h>
#include <Arduino.h>
#include <TuyaWifi.h>
#include "HardwareSerial.h"
//---------RS485 setting
#define DEBUG   1
#define SERIAL_BAUD   9600
#define RX_PIN    32
#define TX_PIN    33
#define ADAPT485_NUM  2
#define SLAVE_ADDR  1
#define READ_ADDR  0
#define READ_NUM   32
/* Current device DP values */
bool rt_coils_status[32] = {0};
HardwareSerial My485Serial(ADAPT485_NUM);
ModbusMaster node;
uint16_t rcv_buf[READ_NUM>>4] = {0};
static void ReadEmeterRegs(void)
  uint32_t read_tmp = 0;
  uint8_t result = node.readCoils(READ_ADDR, READ_NUM);
  if (result == node.ku8MBSuccess) {//if communicate successful then
    for (uint8_t i = 0; i < 2; i++)
      rcv_buf[i] = node.getResponseBuffer(i);
      for(uint8_t j = 0; j < 16; j++)
        if(j<8) rt_coils_status[i*16 + j+8] = (rcv_buf[1-i]&(1<<j))?true:false;
        else rt_coils_status[i*16 + j - 8] = (rcv_buf[1-i]&(1<<j))?true:false;
    #if DEBUG
    Serial1.print("Get switch[0..31] value is");
    Serial1.print(":<0x");
    Serial1.print(rcv_buf[0],HEX);
    Serial1.print(rcv_buf[1],HEX);
    Serial1.println("> ");
    #endif
  else
    node.clearResponseBuffer();
  delay(100);
//---RS485 setting end----
TuyaWifi my_device;
/* Current LED status */
unsigned char led_state = 0;
int key_pin = 25;
/* Data point define */
typedef enum
  DPID_SWITCH01 = 1,
  DPID_SWITCH02,DPID_SWITCH03,
  DPID_SWITCH04,DPID_SWITCH05,DPID_SWITCH06,
  DPID_SWITCH07 = 113,
  DPID_SWITCH08,DPID_SWITCH09,DPID_SWITCH10,
  DPID_SWITCH11,DPID_SWITCH12,DPID_SWITCH13,
  DPID_SWITCH14,DPID_SWITCH15,DPID_SWITCH16,
  DPID_SWITCH17,DPID_SWITCH18,DPID_SWITCH19,
  DPID_SWITCH20,DPID_SWITCH21,DPID_SWITCH22,
  DPID_SWITCH23,DPID_SWITCH24,DPID_SWITCH25,
  DPID_SWITCH26,DPID_SWITCH27,DPID_SWITCH28,
  DPID_SWITCH29,DPID_SWITCH30,DPID_SWITCH31,
  DPID_SWITCH32,
}H32BS_DPID_DEF;
/*const unsigned char dpid_arr[32] = {
  1,2,3,4,5,6,
  113,114,115,116,117,118,119,120,
  121,122,123,124,125,126,127,128,
  129,130,131,132,133,134,135,136,
  137,138,
#define LED_WiFi  26
//#define LED_User  33
*                                     dp type(TuyaDefs.h) : DP_TYPE_RAW, DP_TYPE_BOOL, DP_TYPE_VALUE, DP_TYPE_STRING, DP_TYPE_ENUM, DP_TYPE_BITMAP
unsigned char dp_array[][2] =
  {DPID_SWITCH01, DP_TYPE_BOOL},{DPID_SWITCH02, DP_TYPE_BOOL},
  {DPID_SWITCH03, DP_TYPE_BOOL},{DPID_SWITCH04, DP_TYPE_BOOL},
  {DPID_SWITCH05, DP_TYPE_BOOL},{DPID_SWITCH06, DP_TYPE_BOOL},
  {DPID_SWITCH07, DP_TYPE_BOOL},{DPID_SWITCH08, DP_TYPE_BOOL},
  {DPID_SWITCH09, DP_TYPE_BOOL},{DPID_SWITCH10, DP_TYPE_BOOL},
  {DPID_SWITCH11, DP_TYPE_BOOL},{DPID_SWITCH12, DP_TYPE_BOOL},
  {DPID_SWITCH13, DP_TYPE_BOOL},{DPID_SWITCH14, DP_TYPE_BOOL},
  {DPID_SWITCH15, DP_TYPE_BOOL},{DPID_SWITCH16, DP_TYPE_BOOL},
  {DPID_SWITCH17, DP_TYPE_BOOL},{DPID_SWITCH18, DP_TYPE_BOOL},
  {DPID_SWITCH19, DP_TYPE_BOOL},{DPID_SWITCH20, DP_TYPE_BOOL},
  {DPID_SWITCH21, DP_TYPE_BOOL},{DPID_SWITCH22, DP_TYPE_BOOL},
  {DPID_SWITCH23, DP_TYPE_BOOL},{DPID_SWITCH24, DP_TYPE_BOOL},
  {DPID_SWITCH25, DP_TYPE_BOOL},{DPID_SWITCH26, DP_TYPE_BOOL},
  {DPID_SWITCH27, DP_TYPE_BOOL},{DPID_SWITCH28, DP_TYPE_BOOL},
  {DPID_SWITCH29, DP_TYPE_BOOL},{DPID_SWITCH30, DP_TYPE_BOOL},
  {DPID_SWITCH31, DP_TYPE_BOOL},{DPID_SWITCH32, DP_TYPE_BOOL},
unsigned char pid[] = {"3ocztklfu3q32jab"}; ////change pid here....
/* last time */
unsigned long last_time = 0;
* @param {unsigned char} dpid
* @return {unsigned char}
  int16_t index_out_coil = -1;
  unsigned char get_down_cmd = false;
  for(int16_t i=0;i<32;i++)
    if(dpid == dp_array[i][0])
      index_out_coil = i;
      break;
  if(index_out_coil < 0) return TY_ERROR;
  get_down_cmd = my_device.mcu_get_dp_download_data(dpid,value,length);
  Serial1.print("Rcv Command:<dpid,");
  Serial1.print(dpid,DEC);
  Serial1.print(" value,");
  Serial1.print(value[0],HEX);
  Serial1.print(" len,");
  Serial1.println(length,HEX);
  #if DEBUG
    Serial1.print("get_down_cmd value is:<");
    Serial1.print(get_down_cmd,DEC);
    Serial1.print("Node WriteCoilAddr<");
    Serial1.print(index_out_coil,DEC);
    Serial1.print("> ");
  #endif
  delay(100);
  uint8_t result = node.writeSingleCoil(index_out_coil, value[0]);
  #if DEBUG
    Serial1.print(" result:<");
    Serial1.print(result,DEC);
  #endif
  delay(100);
  my_device.mcu_dp_update(dpid, value, length);
  return TY_SUCCESS;
  My485Serial.begin(SERIAL_BAUD, SERIAL_8N1, RX_PIN, TX_PIN); //RS485 serial port
  node.begin(SLAVE_ADDR,My485Serial);
  Serial.begin(9600,SERIAL_8N1,22,19);  //Tuya module serial port
  Serial1.begin(115200,SERIAL_8N1,3,1);   //USB serial port
  // Serial with tuyawifi
  pinMode(LED_WiFi, OUTPUT);
  digitalWrite(LED_WiFi, LOW);
/*  pinMode(LED_User, OUTPUT);
  digitalWrite(LED_User, LOW);*/
  //Initialize networking keys.
  my_device.init(pid, mcu_ver);
  my_device.set_dp_cmd_total(dp_array, 2);
  //delay(300);
  last_time = millis();
  ReadEmeterRegs();  // read RS485 sensor
  my_device.uart_service();
  //Enter the connection network mode when Pin7 is pressed.
    delay(80);
      if (led_state == LOW) {
        led_state = HIGH;
        led_state = LOW;
  /* report the temperature and humidity */
  if ((my_device.mcu_get_wifi_work_state() == WIFI_CONNECTED) ||
      (my_device.mcu_get_wifi_work_state() == WIFI_CONN_CLOUD)) {
    dp_update_all();
  delay(500);
static bool coils_old_status[32] = {false};
unsigned char tmp_cmd = 0;
static void CompareAndReport(void)
    if(coils_old_status[i] != rt_coils_status[i])
      coils_old_status[i] = rt_coils_status[i];
      tmp_cmd = rt_coils_status[i]?1:0;
      #if 0
      Serial1.print("Changed happed:<dpid,");
      Serial1.print(dp_array[i][0],DEC);
      #endif
      my_device.mcu_dp_update(dp_array[i][0],tmp_cmd, 1);
      delay(10);
      //break;
* @param {*}
* @return {*}
void dp_update_all(void)
  CompareAndReport();
  Kc868-server VS Kincony server 16
Posted by: Saif Kitany - 05-13-2024, 07:43 PM - Forum: News - Replies (3)
What are the differences between kc868- server & kincony server 16?
I want to purchase one of them, but I’m wondering what are the main difference, and which one i should buy for my home project?
  how to install home assistant for Server-16 beginner guide
Posted by: admin - 05-13-2024, 01:33 AM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - No Replies
1. make home assistant SD card for KinCony Server-16.
download  https://www.raspberrypi.com/software/
2. enable i2c for home assistant.
Add files to enable I2C
In the root of the hassos-boot partition, add a new folder called CONFIG.
In the CONFIG folder, add another new folder called modules.
Inside the modules folder add a text file called rpi-i2c.conf with the following content:
i2c-dev
In the root of the hassos-boot partition, edit the file called config.txt add two lines to it:
dtparam=i2c_vc=on
dtparam=i2c_arm=on
3. install HACS addon (use by SSH)
https://hacs.xyz/docs/setup/download/
4. MCP23008/MCP23017 implementation for Home Assistant (HA)
https://github.com/jpcornil-git/HA-mcp23017
5. config yaml for MCP23017
install file edit add-on for HA , then config yaml
https://www.kincony.com/forum/showthread.php?tid=5438
  tuya adapter lost code
Posted by: Saif Kitany - 05-12-2024, 06:17 PM - Forum: News - Replies (3)
i bought 2 new tuya adapter,
first one, i puch the reset button and lost the code in esp chip.
the second one, i tried to dowload the firmeware which support tcp connection, i did the steps as described in this link https://www.kincony.com/forum/showthread.php?tid=2339
but it didnt work. i tried to search the wifi of tuya by my laptob, and can't see it!!!
