Need Advice for New 3-Floor Smart Home Construction Using KinCony Controllers (Nepal)
Hi everyone ❤️,
I am from Nepal and will start building my new house this month. another controller, which is best for 2 floors, there are many channels needed for 50 channel need for 2 floors
I already have a KinCony AIO controller and would like to plan the smart home wiring before construction begins.
I have attached my floor plan. Could you please suggest:
  • Best switch type (momentary/dry contact)
  • I want to bypass the switch also
  • I place the floor-wise DB box and want to install it
  • Recommended sensors (presence, motion, door, water leak, smoke, etc.)
  • RS485 wiring recommendations
  • Any important things I should install now for future expansion
Any suggestions or examples would be greatly appreciated.
Thank you very much! ?
Jitendra
Nepal ??
By the way, I lived in Japan. If any person from Nepal wants to import easily,
.pdf   Top Floor Plan.pdf (Size: 10.63 KB / Downloads: 46)
.pdf   Second Floor Plan (1).pdf (Size: 46.44 KB / Downloads: 41)
.pdf   Ground Floor Plan.pdf (Size: 48.52 KB / Downloads: 39)
.pdf   First Floor Plan (1).pdf (Size: 53.51 KB / Downloads: 40)
i think every floor you can make a smart DB. just you need calculate the channels, then chose BxM series smart controller + DC contactor.
