» Members: 10,121
» Latest member: bestsafedriverdubai
» Forum threads: 4,257
» Forum posts: 21,092
There are currently 538 online users.
» 0 Member(s) | 515 Guest(s)
Amazonbot, Applebot, Baidu, Bytespider, Crawl, Google, PetalBot, Semrush, Sogou web, bot
KC868-A16 ethernet work w...
9 hours ago
» Replies: 31
Update to latest esphome
Last Post: Elgatoguiri
Yesterday, 06:10 PM
» Replies: 4
B32M maximum voltage
Yesterday, 11:52 AM
» Replies: 4
m16v2 energy meter - cali...
10-02-2026, 11:50 AM
» Replies: 15
oCBot: KC868-A6/A16 as a ...
Last Post: oCBot
10-01-2026, 01:32 PM
N20 Energy RS485 Modbus P...
Forum: N20
10-01-2026, 12:43 PM
Getting inconsistent/wron...
10-01-2026, 12:40 PM
KC868-HAv2 phantom press ...
Forum: KC868-HA /HA v2
Last Post: phrfpeixoto
09-29-2026, 01:57 AM
KC868-A6 Analog inputs
Last Post: Tomas4289
09-28-2026, 12:57 PM
N60/N30/N20/N10 PC softwa...
Forum: N10
09-28-2026, 12:49 PM
» Replies: 13
  [arduino code examples for F8]-07 how to DS3231 RTC clock
Posted by: admin - 04-20-2025, 07:15 AM - Forum: F8 - No Replies
* DS3231 RTC with Arduino
* Hardware Connections:
* - SDA: GPIO 8
* - SCL: GPIO 18
#include <DS3231.h>
#include <Wire.h>
typedef struct
  byte month;
  byte day;
  byte hour;
  byte minute;
  byte second;
} MY_DATE_STR;
#define OPEN_RLY_DATA    26
#define OPEN_RLY_MONTH   4
#define CLOSE_RLY_DATA   2
#define CLOSE_RLY_MONTH  5
// Define pin connections
#define SDA_PIN   8
#define SCL_PIN   18
bool h12Flag;
bool pmFlag;
static bool bCentury = false;
static void PrintfCurTime()
  Serial.print(year);
  Serial.print("-");
  Serial.print("-");
  Serial.print(" ");
  Serial.print(":");
  Serial.print(":");
static void GetSerialCmd()
  if (Serial.available() > 0)
    delay(100);
    while (num_read--)
  else return;
  serial_cmd_rcv.trim();
    PrintfCurTime();
    return;
  Serial.print("D index: ");
  Serial.print(indexof_d);
  Serial.print(" T index: ");
  Serial.println(indexof_t);
    return;
  rtc.setDate(my_date_str.day);
  Serial.println("Time set.");
  PrintfCurTime();
  while (Serial.read() >= 0) {}
  GetSerialCmd();
arduino ino file download:
.zip   7-DS3231-RTC.zip (Size: 1.51 KB / Downloads: 665)
.zip   7-DS3231-RTC.ino.merged.zip (Size: 191.08 KB / Downloads: 686)
  [arduino code examples for F8]-06 How to use SD Card
Posted by: admin - 04-20-2025, 07:13 AM - Forum: F8 - No Replies
* SD Card File Operations
* - SCK: GPIO 11
* - MISO: GPIO 12
* - MOSI: GPIO 10
* - CS: GPIO 9
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SCK  11
#define MISO 12
#define MOSI 10
#define CS   9
  File file = fs.open(path);
  if (!file) {
    return;
  while (file.available()) {
  file.close();
  if (!file) {
    return;
  if (file.print(message)) {
  file.close();
  if (!file) {
    return;
  file.close();
  if (fs.remove(path)) {
  static uint8_t buf[512];
  size_t len = 0;
  uint32_t start = millis();
  uint32_t end = start;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len) {
      size_t toRead = len;
      if (toRead > 512) {
        toRead = 512;
      file.read(buf, toRead);
      len -= toRead;
    end = millis() - start;
    file.close();
  if (!file) {
    return;
  size_t i;
  start = millis();
  for (i = 0; i < 2048; i++) {
    file.write(buf, 512);
  file.close();
  // Initialize SPI and SD card
    return;
  if (cardType == CARD_NONE) {
    return;
  if (cardType == CARD_MMC) {
    Serial.println("MMC");
    Serial.println("SDSC");
    Serial.println("SDHC");
    Serial.println("UNKNOWN");
  delay(2000);
  // Perform file operations
  deleteFile(SD, "/hello.txt");
  readFile(SD, "/hello.txt");
  testFileIO(SD, "/test.txt");
  // No operation in loop
.zip   6-SD.zip (Size: 1.53 KB / Downloads: 663)
.zip   6-SD.ino.merged.zip (Size: 221.25 KB / Downloads: 661)
  [arduino code examples for F8]-05 Read free GPIO state
Posted by: admin - 04-20-2025, 07:12 AM - Forum: F8 - No Replies
* @brief Example to read multiple digital inputs using ESP32
* @details This program reads the states of GPIO48, GPIO47, GPIO21, GPIO15, GPIO14, and GPIO40
*          and prints the results to the Serial Monitor.
// Define the GPIO pins for digital inputs
#define INPUT1_PIN 48  // GPIO48
#define INPUT2_PIN 47  // GPIO47
#define INPUT3_PIN 21  // GPIO21
#define INPUT4_PIN 15  // GPIO15
#define INPUT5_PIN 14  // GPIO14
#define INPUT6_PIN 40  // GPIO40
#define INPUT7_PIN 0  // GPIO0
    // Initialize the serial communication for debugging
    Serial.println("ESP32 Digital Input Read Example");
    // Set the input pins as INPUT
    pinMode(INPUT1_PIN, INPUT);
    pinMode(INPUT2_PIN, INPUT);
    pinMode(INPUT3_PIN, INPUT);
    pinMode(INPUT4_PIN, INPUT);
    pinMode(INPUT5_PIN, INPUT);
    pinMode(INPUT6_PIN, INPUT);
    pinMode(INPUT7_PIN, INPUT);
    // Read the state of the digital inputs
    int state1 = digitalRead(INPUT1_PIN);
    int state2 = digitalRead(INPUT2_PIN);
    int state3 = digitalRead(INPUT3_PIN);
    int state4 = digitalRead(INPUT4_PIN);
    int state5 = digitalRead(INPUT5_PIN);
    int state6 = digitalRead(INPUT6_PIN);
    int state7 = digitalRead(INPUT7_PIN);
    // Print the states to the Serial Monitor
    Serial.print("GPIO48 State: ");
    Serial.println(state1);
    Serial.print("GPIO47 State: ");
    Serial.println(state2);
    Serial.print("GPIO21 State: ");
    Serial.println(state3);
    Serial.print("GPIO15 State: ");
    Serial.println(state4);
    Serial.print("GPIO14 State: ");
    Serial.println(state5);
    Serial.print("GPIO40 State: ");
    Serial.println(state6);
    Serial.print("GPIO0 State: ");
    Serial.println(state7);
    // Wait for 500 milliseconds before reading again
    delay(500);
.zip   5-free-gpio-state.zip (Size: 780 bytes / Downloads: 663)
.zip   5-free-gpio-state.ino.merged.zip (Size: 179.5 KB / Downloads: 670)
  [arduino code examples for F8]-04 RS485 communication test
Posted by: admin - 04-20-2025, 07:04 AM - Forum: F8 - No Replies
* RS485 Communication Test
* The TXD pin is defined as GPIO 16 and RXD pin is defined as GPIO 17.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 17
#define RS485_TXD 16
  while (!Serial);
  // Send a test message
  rs485Serial.println("Hello from KinCony F8!");
  // Wait for a short period
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message
    Serial.print("Received: ");
  delay(2000);
.zip   4-RS485-Test.zip (Size: 762 bytes / Downloads: 643)
.zip   4-RS485-Test.ino.merged.zip (Size: 184.34 KB / Downloads: 675)
  [arduino code examples for F8]-03 Read analog input ports value
Posted by: admin - 04-20-2025, 07:03 AM - Forum: F8 - No Replies
* Description:
* This Arduino program reads analog values from four analog input pins (A1, A2, A3, A4)
* and prints the values to the Serial Monitor. The analog inputs are defined with specific
* GPIO pins and the program reads the voltage levels from these pins every 2 seconds.
* Pin Definitions:
* - A1: GPIO 5
* - A2: GPIO 7
* - A3: GPIO 6
* - A4: GPIO 4
#define ANALOG_A1   5   // Define GPIO pin for analog input A1
#define ANALOG_A2   7   // Define GPIO pin for analog input A2
#define ANALOG_A3   6   // Define GPIO pin for analog input A3
#define ANALOG_A4   4   // Define GPIO pin for analog input A4
    delay(500); // Short delay to allow serial communication to start
    pinMode(ANALOG_A1, INPUT); // Set GPIO 5 as an input for analog signal A1
    pinMode(ANALOG_A2, INPUT); // Set GPIO 7 as an input for analog signal A2
    pinMode(ANALOG_A3, INPUT); // Set GPIO 6 as an input for analog signal A3
    pinMode(ANALOG_A4, INPUT); // Set GPIO 4 as an input for analog signal A4
    // Read and print analog values from the defined pins
    Serial.print("A1=");
    Serial.println(analogRead(ANALOG_A1)); // Read and print the value from A1
    Serial.print("A2=");
    Serial.println(analogRead(ANALOG_A2)); // Read and print the value from A2
    Serial.print("A3=");
    Serial.println(analogRead(ANALOG_A3)); // Read and print the value from A3
    Serial.print("A4=");
    Serial.println(analogRead(ANALOG_A4)); // Read and print the value from A4
    delay(2000); // Wait for 2 seconds before the next reading
.zip   3-analog-input.zip (Size: 769 bytes / Downloads: 674)
.zip   3-analog-input.ino.merged.zip (Size: 184.64 KB / Downloads: 680)
  [arduino code examples for F8]-02 Read digital input ports state
Posted by: admin - 04-20-2025, 07:02 AM - Forum: F8 - No Replies
* Description:
* each pin is represented as a bit in a 8-bit value, where each bit corresponds
* Pin Definitions:
* - SDA: GPIO 21
* - SCL: GPIO 22
* - PCF8575 I2C Address: 0x24
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
// Set I2C address
PCF8575 pcf8575_IN1(0x24); // The I2C address of the PCF8575
    Serial.println("KinCony F8 8 channel input state 0:ON  1:OFF");
    uint16_t state = 0;
    for (int pin = 0; pin < 8; pin++) {
        if (pcf8575_IN1.read(pin)) {
    delay(500); // Delay 500ms
.zip   2-digital-input.zip (Size: 839 bytes / Downloads: 634)
.zip   2-digital-input.ino.merged.zip (Size: 189.49 KB / Downloads: 654)
  [arduino code examples for F8]-01 Turn ON/OFF relay
Posted by: admin - 04-20-2025, 07:00 AM - Forum: F8 - No Replies
* This program controls a 8-channel relay board via a PCF8575 I/O expander.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
#define SDA 8            // Define the SDA pin
#define SCL 18           // Define the SCL pin
#define I2C_ADDRESS 0x24 // I2C address of the PCF8575 module
  pcf8575_R1.begin();
.zip   1-relay.zip (Size: 924 bytes / Downloads: 663)
.zip   1-relay.ino.merged.zip (Size: 189.21 KB / Downloads: 691)
  F8 ESPHome yaml for home assistant
Posted by: admin - 04-20-2025, 06:53 AM - Forum: F8 - No Replies
  friendly_name: f8
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
external_components:
  - source:
      type: git
      ref: v1.1.0
  encryption:
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
    i2c_id: bus_a
    pcf8575: true
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 16
    rx_pin: 17
  - id: tuya_mcu_uart
    tx_pin: GPIO39
    rx_pin: GPIO38
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: gk6ok3aysk6lw1bb
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  - platform: uart
    uart_id: uart_1
      number: 8
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "f8_output01"
      number: 9
    dp_id: 2
    internal: true
    bind_switch_id: "f8_output02"
      number: 10
    dp_id: 3
    internal: true
    bind_switch_id: "f8_output03"
      number: 11
    dp_id: 4
    internal: true
    bind_switch_id: "f8_output04"
      number: 12
    dp_id: 5
    internal: true
    bind_switch_id: "f8_output05"
      number: 13
    dp_id: 6
    internal: true
    bind_switch_id: "f8_output06"
      number: 14
    dp_id: 101
    internal: true
    bind_switch_id: "f8_output07"
      number: 15
    dp_id: 102
    internal: true
    bind_switch_id: "f8_output08"
    dp_id: 111
    bind_binary_sensor_id: f8_input01
    internal: true
    dp_id: 112
    bind_binary_sensor_id: f8_input02
    internal: true
    dp_id: 113
    bind_binary_sensor_id: f8_input03
    internal: true
    dp_id: 114
    bind_binary_sensor_id: f8_input04
    internal: true
    dp_id: 115
    bind_binary_sensor_id: f8_input05
    internal: true
    dp_id: 116
    bind_binary_sensor_id: f8_input06
    internal: true
    dp_id: 117
    bind_binary_sensor_id: f8_input07
    internal: true
    dp_id: 118
    bind_binary_sensor_id: f8_input08
    internal: true
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 21
      number: 15
## without resistance on PCB
      number: 14
      inverted:  false
      number: 40
      inverted:  false
      inverted:  false
  - platform: adc
    pin: 5
    name: "f8 A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 7
    name: "f8 A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "f8 A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "f8 A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony F8");
esphome yaml file download:
.txt   F8-HA.txt (Size: 8.67 KB / Downloads: 543)
  KinCony F8 ESP32-S3 IO pins define
Posted by: admin - 04-20-2025, 06:52 AM - Forum: F8 - Replies (1)
ANALOG_A1(0-5v)    GPIO5
ANALOG_A2(0-5v)    GPIO7
ANALOG_A3(4-20mA)  GPIO6
ANALOG_A4(4-20mA)  GPIO4
IIC SDA:GPIO8
IIC SCL:GPIO18
PCF8575:U23  i2c address:0x24
PCF8575->P0 (DI1)
PCF8575->P1 (DI2)
PCF8575->P2 (DI3)
PCF8575->P3 (DI4)
PCF8575->P4 (DI5)
PCF8575->P5 (DI6)
PCF8575->P6 (DI7)
PCF8575->P7 (DI8)
PCF8575->P8 (relay1)
PCF8575->P9 (relay2)
PCF8575->P10 (relay3)
PCF8575->P11 (relay4)
PCF8575->P12 (relay5)
PCF8575->P13 (relay6)
PCF8575->P14 (relay7)
PCF8575->P15 (relay8)
RF433MHz wireless receiver: GPIO40
Ethernet (W5500) I/O define:
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
reset_pin: GPIO1
RS485:
RXD:GPIO17
TXD:GPIO16
Tuya module:
RXD:GPIO38
TXD:GPIO39
1-wire1:GPIO48
1-wire2:GPIO47
1-wire3:GPIO21
1-wire4:GPIO15
1-wire (without resistance on PCB):
1-wire2:GPIO14
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
SPI-CD:GPIO13
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
  [arduino code examples for A8v3]-11 Digital input trigger relay output
Posted by: admin - 04-20-2025, 06:46 AM - Forum: KC868-A8v3 - No Replies
* This program reads 16 input states from a PCF8575 I/O expander and
* controls a corresponding 16-channel relay module. When an input pin
* Pin Definitions:
* - SDA: GPIO 38
* - SCL: GPIO 39
* - Input I2C Address: 0x24
* - Relay I2C Address: 0x25
#include <PCF8575.h>     // Library to control the PCF8575 I/O expander
// Define I2C pins
#define SDA 8           // SDA pin
#define SCL 18           // SCL pin
// I2C addresses
#define RELAY_I2C_ADDRESS 0x22   // I2C address for the relay PCF8575 module
PCF8575 pcf8575_RL(RELAY_I2C_ADDRESS);    // Create an object for the relay PCF8575
  pcf8575_RL.begin();
  // Turn off all relays at the start
  for (int i = 0; i < 8; i++) {
    pcf8575_RL.write(i, LOW);  // Assuming relays are LOW when OFF, setting all relays to OFF initially
  Serial.println("System started: Input state controlling 8 relays");
  uint16_t inputState = 0;
  // Read the state of 16 inputs
    if (pcf8575_RL.read(i)) {
      inputState |= (1 << i);  // If input is HIGH, set the corresponding bit
      inputState &= ~(1 << i); // Otherwise, clear the corresponding bit
  // Control the relays based on the input state
    if (inputState & (1 << i+8)) {
      pcf8575_RL.write(i, HIGH);  // If input is HIGH, turn the relay OFF
      pcf8575_RL.write(i, LOW);   // If input is LOW, turn the relay ON
  // Delay for 500 milliseconds
  delay(500);
.zip   11-input-trigger-output.zip (Size: 1,018 bytes / Downloads: 790)
.zip   11-input-trigger-output.ino.merged.zip (Size: 189.37 KB / Downloads: 694)
