» Members: 10,098
» Latest member: oCBot
» Forum threads: 4,255
» Forum posts: 21,081
There are currently 257 online users.
» 0 Member(s) | 241 Guest(s)
Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, aiohttp/, bot, kagi-fetcher
N20 Energy RS485 Modbus P...
Forum: N20
7 hours ago
Getting inconsistent/wron...
8 hours ago
KC868-HAv2 phantom press ...
Forum: KC868-HA /HA v2
Last Post: phrfpeixoto
09-29-2026, 01:57 AM
KC868-A6 Analog inputs
Last Post: Tomas4289
09-28-2026, 12:57 PM
N60/N30/N20/N10 PC softwa...
Forum: N10
09-28-2026, 12:49 PM
» Replies: 13
getting the A8A inputs to...
Forum: Development
09-28-2026, 08:38 AM
Best way to read from N30
Forum: N30
09-27-2026, 12:20 AM
extend KC868-A16v3
Last Post: bitet96717
09-24-2026, 06:41 AM
Las Firmware ?
09-22-2026, 11:15 PM
» Replies: 8
kc868-a6 analog input
09-21-2026, 11:38 PM
  T16M discovery on linux
Posted by: Kleingy - 03-25-2025, 04:50 PM - Forum: T16M - Replies (1)
I flash m'y T16M with the esp tools in Ubuntu following the procedure I found on the forum.
I put the KCS V3 firmware
But now when I plug the board to my router I am not able to find the ip. The orange led in ethernet port on the board blink. The green one is off.
I can not use the discovery tool, because I am on linux.
Do you have a tool to recommande.
I also search to connect to the wifi Access point. But It does not appear. I read that I have to press a button to re enable the wifi Access point, but which button (I saw dw and reset near antenna), and how to proceed (press before power on, at anytime...).
Thanks for your help
  Integration zigbee and tuya hub with Loxone
Posted by: xxpeta - 03-24-2025, 09:08 PM - Forum: KC868-AG / AG Pro / AG8 / Z1 - Replies (3)
Hello, is it possible to integrate it with Loxone as virtual input and output via UDP or HTTP? If yes, can you provide me more details? Thanks in advance. Petr
  ALR error at uploading
Posted by: Eusaki - 03-24-2025, 08:07 PM - Forum: KinCony ALR - Replies (1)
hi,
Even when the code apparently is uploaded I got this error message ( see last line )
can you please help on this matter?
all drivers installed
test with 3 different USB cables and usb ports
use these boards :
-- ESP32S3 Dev Module
-- fried badge 2024 ( ESP32-S3-WROOM-1)
Quote:Sketch uses 308656 bytes (23%) of program storage space. Maximum is 1310720 bytes.
Global variables use 20436 bytes (6%) of dynamic memory, leaving 307244 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.8.1
Serial port COM13
Connecting...
Chip is ESP32-S3 (QFN56) (revision v0.2)
Features: WiFi, BLE, Embedded PSRAM 8MB (AP_3v3)
Crystal is 40MHz
MAC: d8:3b:da:a8:85:bc
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00004fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x0005bfff...
Compressed 20160 bytes to 12987...
Writing at 0x00000000... (100 %)
Wrote 20160 bytes (12987 compressed) at 0x00000000 in 0.3 seconds (effective 511.2 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 146...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (146 compressed) at 0x00008000 in 0.1 seconds (effective 237.4 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 538.4 kbit/s)...
Compressed 308768 bytes to 164175...
Writing at 0x00010000... (9 %)
Writing at 0x0001bbd1... (18 %)
Writing at 0x0002848e... (27 %)
Writing at 0x0002dcc0... (36 %)
Writing at 0x00033b0d... (45 %)
Writing at 0x0003967e... (54 %)
Writing at 0x0003ebd4... (63 %)
Writing at 0x00044459... (72 %)
Writing at 0x0004b407... (81 %)
Writing at 0x000551ce... (90 %)
Writing at 0x0005b46d... (100 %)
Wrote 308768 bytes (164175 compressed) at 0x00010000 in 2.5 seconds (effective 1005.9 kbit/s)...
Leaving...
Hard resetting with RTC WDT...
A serial exception error occurred: Cannot configure port, something went wrong. Original message: PermissionError(13, 'A device attached to the system is not functioning.', None, 31)
Note: This error originates from pySerial. It is likely not a problem with esptool, but with the hardware connection or drivers.
For troubleshooting steps visit: https://docs.espressif.com/projects/espt...oting.html
Failed uploading: uploading error: exit status 1
  868-A6 Tasmota "Reset"
Posted by: MikeFFB - 03-24-2025, 07:29 PM - Forum: KC868-A6 - Replies (1)
Hello ! Following Problem....I had to change the System including the Wifi....and I forgot to change the Wifi password earlier....how can I reset the Wifi password ?? I tried the Tasmota way....6 times ON/OFF but was not working ? You have an Idea ??? Thank you
  Planned CM5 Upgrade?
Posted by: stansvec - 03-23-2025, 11:12 AM - Forum: KC868-Server Raspberry Pi4 local server - Replies (3)
I recently purchased the mini version and think it's a fantastic idea and product. Do you have any plans to upgrade this series to the new CM5 RPi module?
  B16M Outputs & HomeAssistant Firmware
Posted by: akat - 03-23-2025, 03:06 AM - Forum: Getting Started with ESPHome and Home Assistant - Replies (1)
Hi all,
I've recently deployed a Kincony B16M and flashed it with the stock kincony-b16m.yaml config.
I’m using the digital outputs to control HF41F relays mounted on 41F-1Z-C2-1 boards.
Each relay coil is connected with a 1N4007 flyback diode across A1 and A2. Wiring is as follows:
  • +12V DC to A1
  • 1N4007 across A1 and A2 (cathode on A1)
  • A2 wired to DO1
  • DC port connected to -12V (to complete the circuit)
The issue:
When the B16M boots, DO1 immediately energizes the relay, even though in the WebUI the output appears OFF. Toggling DO1 via the WebUI has no effect on the relay—it remains stuck on. I’ve tried both
inverted: false in the YAML under  b16m-output01, but neither changes the behavior.
Here's the relevant YAML snippet:
      pcf8574: pcf8574_hub_out_1
At this point I’m trying to determine whether I’m dealing with a hardware issue or if there’s a nuance with the output logic I’ve missed. Any insights would be appreciated.
Thanks in advance.
  Dummy question: non-zero voltage between off OUTPUT pin and GND?
Posted by: ocramius - 03-23-2025, 01:25 AM - Forum: T16M - Replies (9)
I'm currently toying around with the T16M before putting it into a wall and calling my project "working".
While experimenting, I started messing around with measurements ( hence my questions on https://www.kincony.com/forum/showthread.php?tid=7423 ).
I've wired my board similar to what I've found in these posts:
* https://www.kincony.com/forum/showthread.php?tid=7211
* https://www.kincony.com/forum/showthread.php?tid=2221 (this schematic is really clear, by the way, thank you!)
While testing out the board, I noticed that the voltage between `V-` and a disabled `V+` pin (see picture below) is **non-zero** (measures 2.385V).
I'm wondering if something is wrong with the board, or if the ESPHome settings don't completely disable the pin?
It may also be a misunderstanding of mine in how MOSFET-based switching works, so feel free to also tell me that my use-case is wrong Big Grin
[Image: pEQGS2V.png]
https://snipfly.io/pEQGS2V.png
  Schematic KC868-A6v3
Posted by: he7neken - 03-22-2025, 10:17 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - Replies (1)
Hi, Is it possible to have the schematics for the KC868-A6v3 board?
  Transmit calculated ADC values via MQTT instead of raw values
Posted by: korl - 03-22-2025, 06:26 AM - Forum: KC868-A series and Uair Smart Controller - Replies (2)
Hello everyone,
I have an A6 and an A16.
On the A6, an analog sensor (1-5V) is connected to ADC1. The sensor measures the air pressure. Via gear symbol, I defined a calculation, so I don't see the raw value, but the reading in bar:
[Image: 2025-03-22-07-19-03-Monitor-und-1-weiter...t-Edge.png]
Via MQTT, only the RAW value is transmitted (see left side of the picture). Is it possible to transmit the calculated value (7.29) and unit (bar), so that a possible home assistant auto discovery also shows the correct unit?
  Disable checkbox for the IFTTT schedule's time setting
Posted by: Yosemite - 03-22-2025, 04:52 AM - Forum: "KCS" v2 firmware system - Replies (4)
Could the next KCS 868 firmware revision include a disable/enable checkbox for the IFTTT schedule's time setting? This would greatly benefit applications that need to run continuously throughout the day, like temperature, pressure, or level control, with varying daily thresholds.
Hardware : KC868 A16
Software  : KCS 868 V2.2.12
