» Members: 10,191
» Latest member: ykbett88com
» Forum threads: 4,264
» Forum posts: 21,145
There are currently 469 online users.
» 0 Member(s) | 446 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, PetalBot, Semrush, bot
SSD not visible for insta...
Forum: Pi5R16
Last Post: Verresen
7 hours ago
» Replies: 10
KC868-A16 and Tuya
Last Post: newdos
Yesterday, 09:33 AM
» Replies: 8
KC868-AI mDNS problem
Forum: KC868-AI
Yesterday, 07:53 AM
remember relay state
Forum: KC868-E16T
Yesterday, 07:51 AM
» Replies: 9
N30 (KCS): energy counter...
Forum: N30
10-09-2026, 11:12 PM
Bricked KC868-A16
10-09-2026, 11:09 PM
» Replies: 7
KinCony G1 ESP32-S3 SIM76...
Forum: News
» Replies: 4
Current direction detecti...
Forum: N30
Last Post: dominique_manas@hotmail.com
10-09-2026, 07:31 AM
» Replies: 4
KC868-A8 on Heat Pump for...
Last Post: marktuan
10-09-2026, 03:17 AM
B32M maximum voltage
Last Post: felixandrea
10-09-2026, 03:14 AM
  [arduino code examples for TA]-06 how to DS3231 RTC clock
Posted by: admin - 04-03-2025, 06:52 AM - Forum: TA - No Replies
* DS3231 RTC with Arduino
* Hardware Connections:
* - SDA: GPIO 8
* - SCL: GPIO 18
#include <DS3231.h>
#include <Wire.h>
typedef struct
  byte month;
  byte day;
  byte hour;
  byte minute;
  byte second;
} MY_DATE_STR;
#define OPEN_RLY_DATA    26
#define OPEN_RLY_MONTH   4
#define CLOSE_RLY_DATA   2
#define CLOSE_RLY_MONTH  5
// Define pin connections
#define SDA_PIN   8
#define SCL_PIN   18
bool h12Flag;
bool pmFlag;
static bool bCentury = false;
static void PrintfCurTime()
  Serial.print(year);
  Serial.print("-");
  Serial.print("-");
  Serial.print(" ");
  Serial.print(":");
  Serial.print(":");
static void GetSerialCmd()
  if (Serial.available() > 0)
    delay(100);
    while (num_read--)
  else return;
  serial_cmd_rcv.trim();
    PrintfCurTime();
    return;
  Serial.print("D index: ");
  Serial.print(indexof_d);
  Serial.print(" T index: ");
  Serial.println(indexof_t);
    return;
  rtc.setDate(my_date_str.day);
  Serial.println("Time set.");
  PrintfCurTime();
  while (Serial.read() >= 0) {}
  GetSerialCmd();
arduino ino file download:
.zip   6-DS3231-RTC.zip (Size: 1.56 KB / Downloads: 675)
.zip   6-DS3231-RTC.ino.merged.zip (Size: 193.66 KB / Downloads: 742)
  [arduino code examples for TA]-05 Read free GPIO state
Posted by: admin - 04-03-2025, 06:50 AM - Forum: TA - No Replies
* ESP32 GPIO State Reader
* Reads the state of 12 GPIOs and prints the results to the serial monitor.
#define GPIO_9   9
#define GPIO_11  11
#define GPIO_5   5
#define GPIO_4   4
#define GPIO_7   7
#define GPIO_6   6
#define GPIO_13  13
#define GPIO_40  40
#define GPIO_14  14
#define GPIO_48  48
#define GPIO_21  21
#define GPIO_47  47
    // Set GPIOs as input
    pinMode(GPIO_9, INPUT);
    pinMode(GPIO_11, INPUT);
    pinMode(GPIO_5, INPUT);
    pinMode(GPIO_4, INPUT);
    pinMode(GPIO_7, INPUT);
    pinMode(GPIO_6, INPUT);
    pinMode(GPIO_13, INPUT);
    pinMode(GPIO_40, INPUT);
    pinMode(GPIO_14, INPUT);
    pinMode(GPIO_48, INPUT);
    pinMode(GPIO_21, INPUT);
    pinMode(GPIO_47, INPUT);
    // Read GPIO states
    int state_9  = digitalRead(GPIO_9);
    int state_11 = digitalRead(GPIO_11);
    int state_5  = digitalRead(GPIO_5);
    int state_4  = digitalRead(GPIO_4);
    int state_7  = digitalRead(GPIO_7);
    int state_6  = digitalRead(GPIO_6);
    int state_13 = digitalRead(GPIO_13);
    int state_40 = digitalRead(GPIO_40);
    int state_14 = digitalRead(GPIO_14);
    int state_48 = digitalRead(GPIO_48);
    int state_21 = digitalRead(GPIO_21);
    int state_47 = digitalRead(GPIO_47);
    // Print GPIO states to the serial monitor
    Serial.printf("GPIO9: %d, GPIO11: %d, GPIO5: %d, GPIO4: %d, GPIO7: %d, GPIO6: %d, GPIO13: %d, GPIO40: %d, GPIO14: %d, GPIO48: %d, GPIO21: %d, GPIO47: %d\n",
                  state_9, state_11, state_5, state_4, state_7, state_6, state_13, state_40, state_14, state_48, state_21, state_47);
    delay(1000); // Read GPIO states every second
.zip   5-free-gpio-state.zip (Size: 737 bytes / Downloads: 750)
.zip   5-free-gpio-state.ino.merged.zip (Size: 181.6 KB / Downloads: 764)
  [arduino code examples for TA]-04 RS485 communication test
Posted by: admin - 04-03-2025, 06:45 AM - Forum: TA - No Replies
* RS485 Communication Test
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 38
#define RS485_TXD 39
  while (!Serial);
  // Send a test message
  rs485Serial.println("Hello from KinCony TA!");
  // Wait for a short period
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message
    Serial.print("Received: ");
  delay(2000);
.zip   4-RS485-Test.zip (Size: 762 bytes / Downloads: 704)
.zip   4-RS485-Test.ino.merged.zip (Size: 186.54 KB / Downloads: 710)
  [arduino code examples for TA]-03 RF433MHz signal decode
Posted by: admin - 04-03-2025, 06:43 AM - Forum: TA - No Replies
  Simple example for receiving
  https://github.com/sui77/rc-switch/
#include <RCSwitch.h>
  Serial.begin(9600);
  mySwitch.enableReceive(digitalPinToInterrupt(12));
  Serial.print("begin test");
  if (mySwitch.available()) {
    Serial.print("Received ");
    Serial.print(" / ");
    Serial.print("bit ");
    Serial.print("Protocol: ");
    mySwitch.resetAvailable();
.zip   3-433-decode.zip (Size: 455 bytes / Downloads: 734)
.zip   3-433-decode.ino.merged.zip (Size: 183.33 KB / Downloads: 743)
  [arduino code examples for TA]-02 Read digital input ports state
Posted by: admin - 04-03-2025, 06:39 AM - Forum: TA - No Replies
* Description:
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x22
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
// Set I2C address
    Serial.println("KinCony TA 12 channel input state 0:ON  1:OFF");
    uint16_t state = 0;
    for (int pin = 0; pin < 12; pin++) {
        if (pcf8575_IN1.read(pin)) {
    delay(500); // Delay 500ms
.zip   2-digital-input.zip (Size: 837 bytes / Downloads: 693)
.zip   2-digital-input.ino.merged.zip (Size: 192.29 KB / Downloads: 732)
  [arduino code examples for TA]-01 Turn ON/OFF relay
Posted by: admin - 04-03-2025, 06:36 AM - Forum: TA - No Replies
// Made by KinCony IoT: https://www.kincony.com
#include <Wire.h>        // Include I2C communication library
#include <PCF8575.h>     // Include PCF8575 library
#define SDA_PIN 8        // I2C SDA pin
#define SCL_PIN 18       // I2C SCL pin
#define RELAY1 14        // Relay 1 (PCF8575 CH15)
#define RELAY2 15       // Relay 2 (PCF8575 CH16)
#define I2C_ADDRESS 0x22 // I2C address of PCF8575
PCF8575 pcf8575(I2C_ADDRESS); // Create PCF8575 object
    Wire.begin(SDA_PIN, SCL_PIN); // Initialize I2C bus
    pcf8575.begin(); // Initialize PCF8575
    // Initialize relay state, default OFF (HIGH)
    pcf8575.write(RELAY1, HIGH);
    pcf8575.write(RELAY2, HIGH);
    Serial.println("All relays are OFF");
    Serial.println("Turning Relay 1 ON");
    pcf8575.write(RELAY1, LOW); // Turn ON relay 1
    delay(2000);
    Serial.println("Turning Relay 1 OFF");
    pcf8575.write(RELAY1, HIGH); // Turn OFF relay 1
    delay(2000);
    Serial.println("Turning Relay 2 ON");
    pcf8575.write(RELAY2, LOW); // Turn ON relay 2
    delay(2000);
    Serial.println("Turning Relay 2 OFF");
    pcf8575.write(RELAY2, HIGH); // Turn OFF relay 2
    delay(2000);
.zip   1-output.zip (Size: 631 bytes / Downloads: 727)
.zip   1-output.ino.merged.zip (Size: 192.13 KB / Downloads: 728)
  TA ESPHome yaml for home assistant
Posted by: admin - 04-03-2025, 06:33 AM - Forum: TA - No Replies
  friendly_name: TA
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
external_components:
  - source:
      type: git
      ref: v1.1.0
#logger:
#  level: DEBUG
#   hardware_uart: USB_SERIAL_JTAG
  encryption:
# ethernet:
#   type: W5500
#   clk_pin: GPIO1
#   mosi_pin: GPIO2
#   miso_pin: GPIO41
#   cs_pin: GPIO42
#   interrupt_pin: GPIO43
#   reset_pin: GPIO44
wifi:
  ssid: KinCony
  password: 'a12345678'
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
    i2c_id: bus_a
    pcf8575: true
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
  - id: tuya_mcu_uart
    tx_pin: GPIO16
    rx_pin: GPIO17
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: asowcylz7am5cbtp
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_out_1
      number: 14
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "ta_output01"
      number: 15
    dp_id: 2
    internal: true
    bind_switch_id: "ta_output02"
    dp_id: 111
    bind_binary_sensor_id: ta_input01
    internal: true
    dp_id: 112
    bind_binary_sensor_id: ta_input02
    internal: true
    dp_id: 113
    bind_binary_sensor_id: ta_input03
    internal: true
    dp_id: 114
    bind_binary_sensor_id: ta_input04
    internal: true
    dp_id: 115
    bind_binary_sensor_id: ta_input05
    internal: true
    dp_id: 116
    bind_binary_sensor_id: ta_input06
    internal: true
    dp_id: 117
    bind_binary_sensor_id: ta_input07
    internal: true
    dp_id: 118
    bind_binary_sensor_id: ta_input08
    internal: true
      number: 8
    dp_id: 119
    bind_binary_sensor_id: ta_input09
    internal: true
      number: 9
    dp_id: 120
    bind_binary_sensor_id: ta_input10
    internal: true
      number: 10
    dp_id: 121
    bind_binary_sensor_id: ta_input11
    internal: true
      number: 11
    dp_id: 122
    bind_binary_sensor_id: ta_input12
    internal: true
##pull-up resistance on PCB
      number: 9
      number: 11
      inverted: false
      inverted:  false
      number: 13
      inverted:  false
      number: 40
      inverted:  false
      number: 14
      inverted:  false
      number: 48
      inverted:  false
      number: 21
      inverted:  false
      number: 47
      inverted:  false
      inverted:  false
      number: 12
      inverted:  false
web_server:
  port: 80
  TA ESP32-S3 IO pins define
SDA:GPIO8
SCL:GPIO18
PCF8575:i2c address:0x22
digital input: CH1-12
relay output: CH15,CH16
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
1-wire1:GPIO9
1-wire2:GPIO11
1-wire3:GPIO5
1-wire4:GPIO4
1-wire5:GPIO7
1-wire6:GPIO6
1-wire7:GPIO13
1-wire8:GPIO40
1-wire9:GPIO14
1-wire10:GPIO48
1-wire11:GPIO21
1-wire12:GPIO47
Ethernet (W5500) I/O define:
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO17
TXD:GPIO16
RF433M receiver: GPIO12
  KC868-A16 rev.1.6 update problem
Posted by: simpl3x - 04-02-2025, 10:01 AM - Forum: "KCS" v2 firmware system - Replies (4)
hi. try to update new device KC868-A16
but have error after 15 sec from start
test offset :  0 0x0
case ok
Uploading stub...
Running stub...
Stub running...
FLASH_CRYPT_CNT 0
ABS_DONE_0 False
Compressed 2081424 bytes to 792650...
[2025-04-02 12:57:04,480][ESP8266Loader_spi[1]][espDownloader.py][line:606][ERROR]: ESP32 Chip flash download error esp_write_flash.
  KC868-A4 - DHT 22
Posted by: ariffakil - 04-02-2025, 09:01 AM - Forum: KC868-A4 - Replies (7)
Dear sir  .,
i like to know  to   which in i hvae to Connect DHT 22  or 11  in KC-868 -A4 1.2.5   borad , i used  pin 13  but  its cant able to reade
