» Members: 10,047
» Latest member: fun79comsse
» Forum threads: 4,252
» Forum posts: 21,057
There are currently 373 online users.
» 1 Member(s) | 355 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, bot, linkcheck, ChrisNZ
getting the A8A inputs to...
Forum: Development
Yesterday, 11:07 PM
extend KC868-A16v3
Last Post: bitet96717
Yesterday, 06:41 AM
Las Firmware ?
09-22-2026, 11:15 PM
» Replies: 8
kc868-a6 analog input
09-21-2026, 11:38 PM
A32 pro tuya
Disconnect loop with Home...
Forum: F16
09-21-2026, 01:16 AM
KC-868-A1 linked Home Ass...
Forum: News
config modbus sensor in K...
09-19-2026, 11:52 AM
remember relay state
Forum: KC868-E16T
09-19-2026, 01:42 AM
Ceiling fan control not w...
09-18-2026, 07:15 AM
» Replies: 11
  KinCony Server16 home assistant yaml for Relay and Digital input
Posted by: admin - 04-02-2024, 04:38 AM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - No Replies
  - platform: mcp23017
    i2c_address: 0x20
    invert_logic: true
    pins:
      0 : Button_1
      1 : Button_2
      2 : Button_3
      3 : Button_4
      4 : Button_5
      5 : Button_6
      6 : Button_7
      7 : Button_8
      8 : Button_9
      9 : Button_10
      10 : Button_11
      11 : Button_12
      12 : Button_13
      13 : Button_14
      14 : Button_15
      15 : Button_16
    i2c_address: 0x22
    hw_sync: false
    invert_logic: true
    pins:
      0 : Output_1
      1 : Output_2
      2 : Output_3
      3 : Output_4
      4 : Output_5
      5 : Output_6
      6 : Output_7
      7 : Output_8
      8 : Output_9
      9 : Output_10
      10 : Output_11
      11 : Output_12
      12 : Output_13
      13 : Output_14
      14 : Output_15
      15 : Output_16
download ymal:
.txt   Server16_HA_config.txt (Size: 919 bytes / Downloads: 645)
use by mcp23017 for HACS github link: https://github.com/jpcornil-git/HA-mcp23017
  KinCony Cloud Server will stop service in 2025 upgrade to TUYA app
Posted by: admin - 04-02-2024, 04:12 AM - Forum: News - Replies (15)
KinCony Cloud server have worked almost 10 years for user freely use.
at the beginning of 2025, will stop service. In order to have a better user experience, we suggest use Tuya app with Tuya cloud server. There are two solution for update your OLD controller to use tuya app.
1. replace with new relay controller for more powerful functions.
8 channel old relay controller: replace with KC868-E8T or KC868-A8S or KC868-A8Sv2
16 channel old relay controller: replace with F16 controller
32 channel old relay controller: replace with A32 Pro controller
2. add tuya adapter let your old controller work with tuya app and support voice control by alexa and google home speaker.
8 channel old relay controller (KC868-H8/H8W):
add tuya adapter v2:https://www.kincony.com/esp32-tuya-iot-adapter-v2.html
video tour: https://youtu.be/zSOtzTXvUiI
16 channel old relay controller (KC868-H16/H16W):
video tour: https://youtu.be/6jevfQFY9A0
32 channel old relay controller (KC868-H32, H32L, H32LW, H32B, H32BS):
add tuya adapter v1:https://www.kincony.com/esp32-tuya-iot-adapter.html
video tour: https://youtu.be/z67pRMLb4Rc
  how to compile new tasmota firmware by simplest way
Posted by: admin - 04-01-2024, 02:07 AM - Forum: KC868-A series and Uair Smart Controller - Replies (5)
1. use Gitpod, you just need a web browser: https://tasmota.github.io/docs/Gitpod/
2. for example:  we make a new tasmota firmware for ESP32 MATTER + enable PCF8574 i2c bus chip.
3. When compiling your build add the following to user_config_override.h
#define USE_I2C                                // Add support for I2C
#define USE_PCF8574                            // [I2cDriver2] Enable PCF8574 I/O Expander (I2C addresses 0x20 - 0x26 and 0x39 - 0x3F) (+2k1 code)
#define USE_PCF8574_SENSOR                  // Enable Mode1 inputs and outputs in SENSOR message (+0k2 code)
#define USE_PCF8574_DISPLAYINPUT            // Enable Mode1 inputs display in Web page (+0k2 code)
#define USE_PCF8574_MQTTINPUT                // Enable Mode1 MQTT message & rule process on input change detection : stat/%topic%/PCF8574_INP = {"Time":"2021-03-07T16:19:23+01:00","PCF8574-1_INP":{"D1":1}} (+0k5 code)
4. after SAVE the FILE, then run command:   "platformio run -e tasmota32"
Command "platformio run -e tasmota32"  is correct for ESP32 builds,  "platformio run -e tasmota"  is only for esp8266 builds.
5. after compiled, download "tasmota32.factory.bin".
6. then use ESP DOWNLOAD TOOL write to ESP32 in address 0x0
7. after re power on of ESP32 board, you can connect with tasmota, config it with I2C SDA and SCL pins firstly, then you can see the PCF8574 option and MATTER option.
Tasmota ESP32 MATTER+PCF8574 firmware download (after downloaded the ZIP file, you need to unzip get the BIN file)
.zip   tasmota32.factory.zip (Size: 1.69 MB / Downloads: 1326)
  which board uses SX1278 LORA???
Posted by: masoos - 03-30-2024, 09:19 PM - Forum: DIY Project - Replies (1)
Hi, which board you show in the picture for SX1278 Wireless Transceiver Module Lora 868Mhz? It has Lora and a small OLED display :-) I want this!!!!
https://ae01.alicdn.com/kf/U580db2b9a8fb....jpg_.webp
https://www.aliexpress.com/item/10050042...2572425%21
  Differences in protocols between H32B and H32B Pro?
Posted by: lulu01 - 03-30-2024, 08:34 PM - Forum: Development - Replies (2)
I want to use a H32B and a H32B Pro with Home assistant.
For the H32B, I used this unofficial integration: https://github.com/fiLLLip/hass-components-sha. It uses the RELAY-SET- and RELAY-READ- commands; you can see the code here https://github.com/fiLLLip/hass-componen..._init__.py. This works very well.
The same code does not work for H32B Pro. Only about 50% of clicks on switches work, and I often get error messages such as 'Failed to call service switch/turn_on. 'NoneType' object has no attribute 'group''.
Is this normal? Do the H32B and the H32B Pro use different protocols? I found the page for the protocol used in H32B, is it not supposed to work the same on the Pro?
Thank you!
  Help to choose the right board
Posted by: Bergoglio - 03-29-2024, 08:13 PM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
Good afternoon,
I need an help to choose the right KC868-A model (I don't want to make a mistake because I must buy 21 pieces....)
My hardware minimum specs :
  1. the board must have an ethernet (rj45) port
  2. min 5 releays NO/NC max load 1 A at 230v
  3. I must connect to every board n. 4 temp sensors DS18B20
What is the best solution ?
  Firm ware
Posted by: STV - 03-29-2024, 01:06 PM - Forum: KC868-A8 - Replies (1)
Can i get Firmware v1.0.9 same as the video tutorial - 2023 new "KCS" firmware for KinCony ESP32 board detailed explanation
  KinCony ESP32 Tuya IoT Adapter V2 released
Posted by: admin - 03-29-2024, 07:36 AM - Forum: News - No Replies
KinCony ESP32 Tuya IoT adapter V2 let relay board or IoT devices easy integrate to tuya IoT platform. We have designed by ESP32 work with Tuya module. Tuya module will connect with Tuya cloud server, when using tuya phone app, message will send to tuya wifi module and decode by ESP32. ESP32 support use arduino IDE to write code, get the tuya message and send any command to RS485 or network device. it’s a good convert tool for smart home automation DIY.
You can add ESP32 Tuya IoT adapter, let your KC868-A series board can use voice control by alexa or google home speaker.
adapter support to use “Tuya MCU SDK Arduino Library”
KC868-H32B,KC868-H32BS …. HxB series smart controller will be easy support TUYA phone application, alexa and google home voice control function.
[Image: esp32-tuya-adapter-v2-1.jpg][Image: esp32-tuya-adapter-v2-4.jpg]
[Image: esp32-tuya-adapter-v2-2.jpg]
[Image: esp32-tuya-adapter-pins-define.jpg]
[Image: esp32-tuya-adapter-v2-6.jpg]
  KinCony Server16 Node-Red testing flows demo example
Posted by: admin - 03-29-2024, 07:35 AM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - No Replies
Node-Red flows download:
.zip   flows-test-English.zip (Size: 3.24 KB / Downloads: 935)
  KinCony Server16 Raspberry Pi iot gateway CM4 GPIO pins define
Posted by: admin - 03-29-2024, 07:33 AM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - No Replies
