» Members: 9,825
» Latest member: jainsimmy270
» Forum threads: 4,217
» Forum posts: 20,918
There are currently 390 online users.
» 2 Member(s) | 362 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, Semrush, Yandex, bot, kulibin, philippe
Last Post: viko
13 minutes ago
» Replies: 13
No ethernet communication
11 hours ago
» Replies: 8
N60 Loss of kWh on reset
Forum: N60
Last Post: chuyskywalker
Yesterday, 03:58 AM
» Replies: 12
CT Sensor Direction
Forum: N60
09-03-2026, 12:51 PM
Request for Type B Projec...
Last Post: lemanat
09-03-2026, 08:47 AM
KinCony CO16 ESP32S3 16 C...
Forum: News
09-02-2026, 01:51 AM
08-31-2026, 12:16 AM
08-31-2026, 12:11 AM
08-31-2026, 12:09 AM
08-31-2026, 12:08 AM
  how to use analog output 0-10V DAC by esphome for home assistant
Posted by: admin - 11-10-2023, 07:14 AM - Forum: Getting Started with ESPHome and Home Assistant - No Replies
  how to use 4-20mA / 0-5v analog sensor by esphome for home assistant
Posted by: admin - 11-10-2023, 07:13 AM - Forum: Getting Started with ESPHome and Home Assistant - No Replies
  publish sensor initial state at boot on home assistant after power failure
Posted by: admin - 11-10-2023, 07:12 AM - Forum: Getting Started with ESPHome and Home Assistant - Replies (2)
  4-20mA Scale for IFTTT is not Precise
Posted by: job-systems - 11-08-2023, 01:12 AM - Forum: KC868-A4 - Replies (3)
Hi everyone, I am new to Kincony products, and have liked them very much until now.
I have 12x KC868-A4 boards and 24x Dwyer DM-200 Differential Pressure Transmitters connected to the A4 boards on the A1 and A2 inputs that are 4-20mA. (Please refer to enclosed file: Dwyer DM-200).
The DM-200 Transmitter has a range (measured and confirmed) of 4mA = 0 Pascal (Pa) and 20mA = 62.21 Pa (Please refer to enclosed file: Instrument Scale), therefore, I assumed that Custom Value 1 is 0 Pa and Custom Value 2 is 62.21 Pa (Please refer to enclosed file: 4-20mA Scale).
When we go to "Monitor" icon to see what values Kincony is reading live at around 37 Pa on Dwyer, Kincony is showing 35 Pa, and at 0 Pa on Dwyer, Kincony is showing around 8 Pa. The 4-20mA signal is clearly arriving to Kincony, we checked the values of the signal and we get 4mA and around 12 to 14 mA when values of 30 and up Pascal.
Thinking we where doing something wrong, we put: Custom Value 1 to "-15.56" Pa and Custom Value 2 to 62.21 Pa, like Instrument Scale picture, and values were also not coincident.
We think there is a problem with scaling inside the KCS_KC868_A4_V2.1.9 firmware.
Can you check? And let me know?
Thank you.
Image(s)
.pdf   Dwyer DM-200.pdf (Size: 471.25 KB / Downloads: 831)
  Multiple I2C PORTs.
Posted by: djconcept - 11-07-2023, 08:51 PM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - Replies (2)
Hello, I would like to understand the logic, on the board, I find 3 I2C ports:
I2C-0
I2C-1
I2C-10
When i make this:
ls /dev/*i2c*
I receive this
/dev/i2c-1  /dev/i2c-20  /dev/i2c-21
what exactly is the link?
Thank you in advance for your support.
  5v sensor
Posted by: gilad - 11-07-2023, 07:51 AM - Forum: KC868-A4 - Replies (1)
i need A4 module to drive 5v IR module with length of cable of up to 2 meter.
our can i get the 5v
  IR LED extention cable
Posted by: gilad - 11-07-2023, 07:34 AM - Forum: KC868-A4 - Replies (5)
seeking to have the IR LED extended to 2 meter cable.
is it going to be supported ?
VCC
DATA
GND
  how to use switch button by esphome for home assistant
Posted by: admin - 11-07-2023, 12:25 AM - Forum: Getting Started with ESPHome and Home Assistant - No Replies
  how to use gpio binary sensor by esphome for home assistant
Posted by: admin - 11-07-2023, 12:23 AM - Forum: Getting Started with ESPHome and Home Assistant - No Replies
  KC868_A8 relay not vorking
Posted by: Aiot - 11-06-2023, 06:44 PM - Forum: "KCS" v2 firmware system - Replies (1)
I have this board and I install kcs v2 firmware on the board but relays not working. Any idea?
Board
