» Members: 9,944
» Latest member: uu88isscom
» Forum threads: 4,244
» Forum posts: 21,021
There are currently 116 online users.
» 0 Member(s) | 97 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, HeadlessChrome, PetalBot, bot
Modbus 485 extender kcs V...
Forum: N30
2 hours ago
» Replies: 7
Ceiling fan control not w...
2 hours ago
» Replies: 9
Case
Forum: KC868-A16S
Yesterday, 02:26 AM
KC868-A16S PCB layout CAD...
09-14-2026, 11:23 PM
flash kc868-a4
09-14-2026, 11:18 PM
» Replies: 25
KC868-A16 – Using AI3/AI4...
09-14-2026, 08:27 AM
Questions on CO16
09-13-2026, 01:26 PM
RED DIP switch function
Forum: Pi5M32
09-12-2026, 11:50 PM
Forum: Pi5R32
Forum: Pi5M16
  need help about uair
Posted by: ahmedwizza1 - 10-18-2023, 11:06 AM - Forum: News - Replies (11)
hello engineer
I have 3 u air in me project
but their is no more video about this product to show how to use as same as anther product
so please any product .make more more video about that
Because we are technical not engineer ..
so this my problem....I already add u air to my home assistant and cannot how to add any remote signal
and cant control for the RGB
and give me  error IP connection
need help
Huh Huh Huh Huh Huh Huh Huh Huh Huh
attach the Yamal file
.txt   uair.txt (Size: 2.41 KB / Downloads: 620)
  KC868-A64 wiring diagram
Posted by: KinCony Support - 10-16-2023, 07:06 AM - Forum: KC868-A64 - No Replies
  KC868-HA RS485 INPUT & OUTPUT plugin for ESPHome
Posted by: admin - 10-16-2023, 04:50 AM - Forum: KC868-A series and Uair Smart Controller - Replies (55)
Use this plugin for ESPHome. you can add everyone KC868-HA board with 6 digital input ports and 6 digital output ports to home assistant. "digital input" can use for switch panel buttons or dry contact sensors. "digital output" can use for LEDs or extend relay module (need add driver).
how is config yaml file demo details: https://github.com/hzkincony/esphome-kc868-ha
Posted by: admin - 10-16-2023, 04:50 AM - Forum: KC868-HA /HA v2 - Replies (29)
  KC868-HA RS485 button adapter PC software V1.0.5.1011
Posted by: admin - 10-16-2023, 03:24 AM - Forum: News - No Replies
improvement:
support KC868-HA v2 PCB.
support Baud rate modifiable for KC868-HA v2 PCB.
download:
.zip   HA485_Ctrl_V1.0.5.1011.zip (Size: 911.88 KB / Downloads: 943)
  KC868-HA RS485 button adapter firmware V107_SP231010
Posted by: admin - 10-16-2023, 02:59 AM - Forum: News - No Replies
improvement:
fixed CRC error
firmware download:
.zip   HA485_KU_V107_SP231010.zip (Size: 6.42 KB / Downloads: 1081)
  [KC868-AG PRO] Tuya and scenes
Posted by: zolax - 10-15-2023, 08:29 AM - Forum: KC868-A series and Uair Smart Controller - Replies (14)
I need to control 40 Tuya window actuators with one RF433MHz remote control.
For this I need to read 40 x 2 signals (window opening and closing) RF433MHz from my 99CH RF remote and create scenes in TUYA. The Kincony device is intended to act as an intermediary between the 99CH RF433MHz remote control (not Tuya) and the actuators (Tuya).
Previously, I bought KC-868-A4, but it only supports 32 RF signals and 4 outputs (I only need virtual ones for tuya), which practically allows for the control of only 4 actuators.
I bought KC868-AG PRO and the problem is that:
- in KC868-A4 PRO for e.g. output 1 there was a signal: output1:off, output 1:on and it worked very well
- in KC868-AG PRO I create e.g. Window Pusher, configured the RF signal but I have no on/off condition, only e.g. Scene1: scene and it doesn't work
  Domoticz Plugin
Posted by: oxedgar - 10-13-2023, 09:05 PM - Forum: KC868-A16 - Replies (14)
Can you please update your Plug-in for domoticz to add support for KC868-A16?
I've been added with MQTT but i have many loop problems! If anybody have added Kincony products with mqtt . pls help me to make it working without toggle loops?
  KC868-A32M wiring diagram
Posted by: KinCony Support - 10-13-2023, 07:02 AM - Forum: KC868-A32M - Replies (3)
  how to wire OUTPUT voltage from power supply for KC868-A128
Posted by: admin - 10-13-2023, 12:31 AM - Forum: KC868-A128 - No Replies
