I am currently using KC868 A16 board with esphome in my homeasssistant. Flashing the board was succesful. I used the yaml code as shown here: https://www.kincony.com/forum/showthread.php?tid=1628
Outputs from 1 to 16 all are shown in homeassistant dashboard. I am able to even turn on and off from the HA dashboard but nothing changes in the A16 board. Only the output 9 and 10 works. Rest of the outputs show no changes. I have attached my yaml code in .txt file below.
A16.txt (Size: 5.55 KB / Downloads: 719)
thank you
Good afternoon! I ran into the following problem: when connecting a temperature sensor DS18B20, it shows a value from 0 and more. It does not show a negative temperature. What could this be related to? The board is KS868-A4, Software Version v2.1.9. The sensor is now installed outside the window. The temperature outside is "-7" C. The length of the sensor cable is 0.7 m. I have two such sensors and both give the same readings.
I just received my M16-v2.1 board and will use it with 10A and 20A 0-1V clamps. New to the forum :-)
I'm on a 3x400V+N network and connected L1, L2, L3 and N to the terminals to measure the voltage.
But the voltages that are reported seem to be too low.
I also have a Zennio Kes Plus KNX device that also measures voltage and power consumption. (top 3 values in image below).
I also tried 2 different multimeters and get nearly the same readings as the Zennio (and I measured on the inputs of the M16)
But the M16 readings are 8-12 volts lower.
Is there a way to calibrate the voltages?
I'm using home assistant with ESPhome
If not: can I use the voltages from another home assistant entity (my Zennio) and use these?
After that I would like to start calibration of the CT-clamps: is it advised to do individual clamp calibration for each connection?
I have searched for the same spec:
- 0-10VDC Control Input
- 0-250VAC Output
There's any additional spec that I should pay attention when looking for alternative ? Because the relays that I've bought are not working, when I change the dimmer bar their led don't even power up....
The pictures of relays are attached.
I found the full spec of the ssr relays voltage regulator I have
I would like to present the following problem.
I have four Kincon controllers of the following type:
2 pcs. KC868-AIO
2 pcs. KC868-A8
Problems related to loss of communication in one KC868-A8 controller
The other drivers do not have this type of problem and work stably
Both KC868-AIO controllers have the same network configuration saved in the controller memory.
I wonder what could be the reason for the loss of Ethernet communication if at the same time the other controllers are working stably.
