» Members: 10,008
» Latest member: DiRay
» Forum threads: 4,252
» Forum posts: 21,052
There are currently 33 online users.
» 0 Member(s) | 21 Guest(s)
Amazonbot, Bytespider, Crawl, PetalBot, bot
Las Firmware ?
9 hours ago
kc868-a6 analog input
9 hours ago
A32 pro tuya
9 hours ago
Disconnect loop with Home...
Forum: F16
Yesterday, 01:16 AM
KC-868-A1 linked Home Ass...
Forum: News
Yesterday, 01:16 AM
config modbus sensor in K...
09-19-2026, 11:52 AM
remember relay state
Forum: KC868-E16T
09-19-2026, 01:42 AM
getting the A8A inputs to...
Forum: Development
09-19-2026, 01:41 AM
Ceiling fan control not w...
09-18-2026, 07:15 AM
» Replies: 11
Output pin protection
Forum: T16M
09-17-2026, 11:44 PM
  Need firmware with MQTT for Smart dimmer
Posted by: Gooogle - 05-14-2021, 06:55 AM - Forum: KC868-HxB series Smart Controller - Replies (7)
There will be firmware for Smart dimmer with MQTT
  [KC868-H32B][MQTT] Home Assistant switches do not restore state after reboot
Posted by: basten - 05-12-2021, 08:44 PM - Forum: KC868-HxB series Smart Controller - Replies (4)
Home assistant switches work well via ethernet MQTT but do not restore their states after HA reboot (all stay off). Firmware version is H32B_V4.24.
Information Will the KC868-H32L MQTT get support?
Posted by: ANDRU - 05-10-2021, 12:23 PM - Forum: KC868-HxB series Smart Controller - Replies (1)
Good afternoon, I use KC868-H32L. Will there be an update with the MQTT connection feature? Thank you in advance))))
  KC868-H32B V4.24 new firmware update
Posted by: admin - 05-10-2021, 01:54 AM - Forum: News - Replies (12)
improvement:
1. Support ALL ON/OFF button by home assistant via ethernet MQTT.
KC868-H32B V4.24 firmware download:
.zip   Relay32_V424_210509.zip (Size: 44.37 KB / Downloads: 1235)
  KC868-H32B V4.23 new firmware update
Posted by: admin - 05-05-2021, 07:14 AM - Forum: News - Replies (4)
improvement:
1. Support MQTT by ethernet.
2. Fixed bug that can't use 2pcs KC868-H32B by WiFI MQTT at the same time. Now no limit, multi controller can be used at the same time.
3. Relay "Momentary Time" extend to "1-10000 seconds"
4. add scan device Broadcast command for UDP. This command for software developer scan KC868-H32B in network.
use local network port=4000  send Ansi-String "scan" to remote IP:255.255.255.255 Port:4001
all KC868-H32B in same network device will feedback: device's IP,Port,UID,type
for example:
send->scan
feedback: 192.168.1.200:4196,uid:xxxxxxxxxxxxxxxxxxxxxxxx,type:H32B
KC868-H32B V4.23 firmware download:
.zip   Relay32_V423_210505.zip (Size: 44.96 KB / Downloads: 1099)
  how to add multiple controllers to home assistant? by MQTT
Posted by: Gooogle - 04-27-2021, 05:54 AM - Forum: KC868-HxB series Smart Controller - Replies (6)
How to describe configuration.yaml
I have two controllers KC868H32B version 4.20
mqtt:
  broker: 192.168.0.10    #home assistant IP
  port: 1883                   #Port
  username: abc # first controller
  password: 123
                        # how to add second or the third controller?
And how to add severals controllers to Mosquitto broker configuration?
  MQTT Firmware for KC868-H4 and H8
Posted by: Ramirez22 - 04-25-2021, 03:45 PM - Forum: KC868-HxB series Smart Controller - Replies (1)
Long time ago, I develop Domoticz plugin with scrutating loop for inputs (the ALARM function isn't able to detect push button action) (Here)
Now, I want to change and use Home Assistant.
I read on forum that Kincony card can work with MQTT and I think that will help me a lot to avoid develop another plugin.
My relay interfaces are H8 and H4, rev 1.1.
I more recently bought a ST-LINK for upgrade firmware.
Is it possible to have confirmation that my interfaces can work with MQTT and in this case, have the firmware please ?
Many thanks for your help (and sorry if my English is not perfect : I'm French Big Grin )
Regards
  Is there a solution? How i can configure the switch board
Posted by: Gooogle - 04-23-2021, 10:49 AM - Forum: KC868-HxB series Smart Controller - Replies (1)
.pdf   Kincony switch configure.pdf (Size: 155.13 KB / Downloads: 1237)
  KC868-COLB V1.8 new firmware for MQTT update
Posted by: admin - 04-20-2021, 02:36 AM - Forum: News - Replies (2)
improvement:
1. KC868-COLB default set "enable" for  auto upload function, before version default is "disable".
2. Fixed problem that if have a DS18B20 temperature value auto loaded, other temperature sensors will stop upload, until temperature value changed will auto upload again. Now all DS18B20 temperature sensor will all auto upload.
3. Support use MQTT function by ethernet. it will easy integrate to third-party software, like home assistant, details see our tour: https://www.kincony.com/knowledge/home-assistant
KC868-COLB V1.8 firmware download:
download the ZIP file , unzip update the bin file for KC868-COLB logical controller.
.zip   AD_COLB_V1_1_8_210419.zip (Size: 41.58 KB / Downloads: 1120)
  Transfer our own binaries to the system?
Posted by: FRANCISCO2020 - 04-15-2021, 04:40 PM - Forum: Development - Replies (15)
Is it possible to obtain a schematic to be able to fully program the unit with our application? or way to transfer our own binaries to the system?
Thanks and best regards
