» Members: 9,880
» Latest member: havanawinter
» Forum threads: 4,228
» Forum posts: 20,970
There are currently 42 online users.
» 0 Member(s) | 32 Guest(s)
Amazonbot, Applebot, Baidu, Crawl, PetalBot, bot
"KCS" v2.2.21 firmware BI...
5 hours ago
KC868-A16 Outputs Y01-Y16...
Yesterday, 11:15 PM
wish
Forum: KC868-A16v3
Yesterday, 01:14 PM
Last Post: viko
Yesterday, 11:39 AM
» Replies: 22
N10 - ESPHome - ARM CPU s...
Forum: N10
Yesterday, 10:20 AM
B32M maximum voltage
Last Post: velifetime
09-08-2026, 07:01 AM
KNX ETS software project ...
09-08-2026, 03:44 AM
"KCS" v3.27.1 firmware BI...
09-08-2026, 03:24 AM
OLED not found in I2C sca...
Forum: KC868-A6v3
09-07-2026, 02:55 AM
"KCS" v3.27 firmware BIN ...
09-07-2026, 02:51 AM
Exclamation KC868-S Install
Posted by: Edimar3103 - 01-23-2021, 01:57 AM - Forum: KC868-HxB series Smart Controller - Replies (1)
I´m not able to install the KC868-S in the App (IOs).
I´m following the KC868-G installation guide because I didn´t find a KC868-S installation guide.
When I proceed witch the following instruction:
Following, back to 【mine】--click【WIFI setting】--input your wifi account and password-- Then click the reset key on the gateway--when the yellow light flashed-- click 【confirm connection】in the APP. At this moment, the red light of the gateway keeps on, then cut off the power and re-power The gateway, the green light will turn on.(Internet connecting success) (the lights perhaps change little slowly, pls wait for about one minute)
I face 2 issues:
1 - There is no yellow light fleshing;
2 - When I click in the "Connect" in the app to stabilish an WI-FI connection a receive the mensage "Connection failled".
Please, any help to install the KM868-S.
Best regards,
  k868 COL and Domoticz
Posted by: acedera - 01-22-2021, 02:25 PM - Forum: Development - Replies (13)
Hello! Is it possible to connect COL and Domoticz?
  COL - bus485
Posted by: athxp - 01-20-2021, 06:39 PM - Forum: KC868-HxB series Smart Controller - Replies (4)
good morning, i wanted to install the power meter for COL. I saw that it communicates with COL in bus 485. through ifttt is it possible to program the outputs commanded at certain read power values? Does COL also accept other peripherals connected on the 485 bus? thanks
  Turn OFF 1st Pump and Turn "ON" pump interval
Posted by: subas - 01-20-2021, 05:13 AM - Forum: Development - Replies (1)
Dear Admin.
Need some advice on which product that you have to control a maximum of 4 pumps where the logic are as per below:
1. Turn "ON" first pump
2. After 30min of pumping turn "OFF" pump 1
3. After 5min of pump 1 in "OFF" condition, Turn "ON" pump 2
4. After 30min of pump 2 running "ON" condition, turn "OFF" pump 2
Could you please suggest which product that you have that can help me do the above?
  BUTTON SWITCH MODULE - How to add 2 remote controller to 1st channel?
Posted by: Kam5 - 01-19-2021, 06:39 PM - Forum: KC868-HxB series Smart Controller - Replies (1)
Dear Admin I would like to connect 2remote controller from button switch board to operate only channel from 1-16 outputs. i don't need to use other outputs.
On the video You show how to add 2 remote controller to use all outputs. Please help with this solution.
Huh
  how to make android app from website by android studio
Posted by: admin - 01-19-2021, 01:06 PM - Forum: Development - Replies (3)
if you have create the webpage on your own server by Node-Red, now this tour will help you to make a own android app from webpage.
we have write the lesson step by step using android studio.
.pdf   how to make android app from website.pdf (Size: 2.18 MB / Downloads: 5158)
  KSmart android app without LOGO version released for distributor
Posted by: admin - 01-18-2021, 04:45 AM - Forum: News - Replies (6)
"KSmart" android phone app function as same as "KinCony smart home" app, just changed the app name , ico and startup page in app. without KinCony's LOGO for project distributor.
here is download link: https://www.kincony.com/download/KSmart.apk
  Node-Red-flows for KC868-D8 dimmer with AWS EC2 Cloud Server
Posted by: admin - 01-13-2021, 02:56 AM - Forum: Development - No Replies
Create the website connect with your own server and remote control 8 channel dimmer output.
.zip   KC868-D8-AWS-EC2.zip (Size: 1.97 KB / Downloads: 1005)
  Node-Red-flows for KC868-G WiFi gateway with AWS EC2 Cloud Server
Posted by: admin - 01-12-2021, 01:55 AM - Forum: Development - No Replies
Create the website connect with your own server.
1. send RF433MHz command for wireless switch panel
2. send IR signal command to control IR device (like TV, DVD, Air conditioner, Fan .....  any have IR remoter's device)
.zip   KC868-G-WiFi-Controller-AWS-EC2.zip (Size: 11.78 KB / Downloads: 1000)
Bug KC868-H32B Parallel Actions
Posted by: mfauziii - 01-09-2021, 12:31 AM - Forum: KC868-HxB series Smart Controller - Replies (9)
I had created a simple flow within my home assistant using toggle switch to control few switches. The switch work normally only if the switches are turn on/off one by one but when simultaneous actions triggered, only few switches are turn on/off. I attach a video for this scenario.
Could anybody suggest a better way to make a parallel/simultaneous actions work.
Node-red flow diagram
