» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 386 online users.
» 0 Member(s) | 359 Guest(s)
Amazonbot, AwarioBot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, Semrush, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  KC868-AM ESP32 IO Expansion Board released
Posted by: admin - 03-18-2023, 02:31 AM - Forum: News - No Replies
We have designed ESP32 IO Expansion (development) Board — KC868-AM (Mini) . it’s ESP32 module + many free GPIOs for home automation DIYer to use. 4 GPIOs in greent terminal already added pull up resistance, so that you can conveniently connect with 1-wire sensor device. some others input GPIOs on the PCB center for user. Support add to home assistant by ESPHome.
[Image: KC868-AM-1_small.jpg]
  KCS Question.
Posted by: Philadam - 03-17-2023, 04:12 AM - Forum: "KCS" v2 firmware system - Replies (7)
Two questions:
1) Is it possible to have an ADC sensor trigger an Input on an A16 with KCS?
2) Will a KC868-HA work with the A16 over RS485?
  KC868-A256 configure yaml for ESPhome
Posted by: admin - 03-16-2023, 05:46 AM - Forum: KC868-A256 - No Replies
.txt   HA_A256.txt (Size: 74.43 KB / Downloads: 1294)
  KC868-A256 ESP32 I/O pin define
Posted by: admin - 03-16-2023, 05:42 AM - Forum: KC868-A256 - Replies (2)
#define ANALOG_A1  GPIO36
#define ANALOG_A2  GPIO39
#define ANALOG_A3  GPIO34
#define ANALOG_A4  GPIO35
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
RS485:
RXD:GPIO13
TXD:GPIO14
74HC595 for output:
Data: GPIO5
Clock:GPIO16
Latch:GPIO4
74HC165 for input:
Data: GPIO15
Clock: GPIO32
LD(load_pin): GPIO33
  KC868-AM configure yaml for ESPhome
Posted by: admin - 03-16-2023, 05:39 AM - Forum: KC868-AM - Replies (2)
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
    pin: 15
    inverted: False
.txt   ESPHome_KC868-AM.txt (Size: 340 bytes / Downloads: 763)
  KC868-AM ESP32 I/O pin define
Posted by: admin - 03-16-2023, 05:38 AM - Forum: KC868-AM - No Replies
Relay1:15
1-wire GPIO for DS18B20/DHT11/DHT21/LED strip -1: 5
1-wire GPIO for DS18B20/DHT11/DHT21/LED strip -2: 14
1-wire GPIO for DS18B20/DHT11/DHT21/LED strip -3: 13
1-wire GPIO for DS18B20/DHT11/DHT21/LED strip -4: 33
#define ETH_ADDR        0
RS485:
RXD:35
TXD:32
IIC BUS:
SDA:4
SCL:16
free GPIOs on PCB hole:
I36
I37
I38
I39
I34
  KC868-A2 configure yaml for ESPhome
Posted by: admin - 03-16-2023, 05:32 AM - Forum: KC868-A2 - Replies (21)
KC868-A2 configure yaml for ESPhome by Ethernet or WiFi.
.txt   ESPHome_KC868-A2-ethernet.txt (Size: 732 bytes / Downloads: 1499)
.txt   ESPHome_KC868-A2-wifi.txt (Size: 875 bytes / Downloads: 1201)
  KC868-A2 ESP32 I/O pin define
Posted by: admin - 03-16-2023, 05:31 AM - Forum: KC868-A2 - Replies (16)
Relay1:15
Relay2:2
DS18B20/DHT11/DHT21/LED strip -1: 33
#define ETH_ADDR        0
RS485:
RXD:35
TXD:32
GSM:
RXD:34
TXD:13
DI1:36
DI2:39
IIC BUS:
SDA:4
SCL:16
  wifi port as AP in home Assistant
Posted by: sve - 03-15-2023, 06:34 PM - Forum: KC868-A8S - Replies (1)
Hello friends,
Is there are possibility to use LAN port for connection to the local network, and wifi to be used like AP for connecting other smart devices? Everything of that configurated within esphome. Currently I use KC868-A8S with Home assistant, and it is connected with a wifi. Also I can't change the configuration to be connected with ethernet port.
Thanks a lot
Thumbs Up How to connect PZEM004T AC Sensor in KC868 series products?
Posted by: kovalank - 03-15-2023, 01:51 AM - Forum: DIY Project - Replies (5)
Your products are very useful and those are present & futuristic designs, I have planned for 16 relay control, 4 Analog sensors, 4 Temperature sensors, and Eneryg Monitor(like PZEM004T)
before that, I have some doubts, Can I use the PZEM004T AC sensor in KC868 A16 or KC 868 A32? if yes how to use please explain in depth.
Or any other suggestions, please? advance Thanks for your reply  Smile
